January 15, 20197 yr Hello, I entered my login data for Windows News website and Enpass stored the data correctly. At the website the login is done by my username (not by email address). Today I downloaded the app of the Windows News website. Here the login works with the email address (not with the username). So I went back to the website entered my email address and copied the password from Enpass to the password field. Here Enpass showed the "Add new Entry" dialog. Suggestion If there is an existing entry in Enpass and the user logs in with a different username but with the same password, ask if the existing entry should be updated or if a new entry should be created. The same dialog that you show already when I enter a different password. Best regards OLLI
