Images in the vault
As I can vaguely remember, you mentioned somewhere that it was not advised to store large amount of images in the version 5 vault as it would grow large and be difficult to synchronize.
Is it correct that this is solved with version 6? As I understand it, images are stored in separate files now and if added, they are synchronized only once and if they are not changed they will not impose any additional sync time or resources?
Hi @stigvi,
Thats true. Attachments are kept in separate files in Enpass 6, they are synchronized only when restored, added or deleted.
Cheers:)
3 minutes ago, Vinod Kumar said:
Hi @stigvi,
Cheers:)
Thanks and nice to know.
