February 1, 20197 yr Focus on first item in parent view In Enpass extension, when you open the modal, focus is on the search field. Most of the time, I need to use the first list item instead. Why not focusing on the first list item by default? Then starting to type would filter the list. Focusable fields in child view Also, when you are in the child view (password details), it's not possible to navigate between fields. Would be nice to enable tab-index on them so that I can copy just one field only with keyboard navigation. Back and forth between parent and child view Also, when you go back to the parent view with arrow left (from child view), focus is both on search field and list item. Because of that, you can't press arrow right to go back to the child view. Disabling autofocus on search field in the parent view would solve the issue.
February 5, 20197 yr Hey @Luc, Thanks for writing in. I have noted it down and forwarded to the dev team for further improvement. Thanks for your co-operation.
