Option to reopen Assistant on the same item
Would it be possible to include an option that would keep last viewed item opened after Assistant is closed and then opened again? My usual workflow with Enpass (and I'm using it often each day) looks like this:
  1. Open Assistant, search for an item
  2. Click info icon to open the item
  3. Copy the login/username value
  4. Paste that value into the login box (Assistant now closes itself)
  5. Open Assistant again, search for same item again
  6. Click info icon to open the item
  7. Copy the password value
  8. Paste the value into the login box
So eight steps that could be boiled down to six if only that second search + open part could be omitted.
Hey @VIr
The suggested feature is already in our roadmap and will be available with the subsequent update.
Cheers!
