February 3, 20197 yr Hello, I activated 2FA for my Ubisoft account. Now the 2FA code must be entered when I start the Ubisoft uPlay Client (Windows application). If you implement the Login into Desktop Applications: then Enpass should also copy the 2FA Code into the clipboard after logging me into the application. Best regards OLLI
February 3, 20197 yr Author Hello, also the game Star Citizen allows 2FA codes generated by an Authenticator app. Best regards OLLI
