I am a new user to Enpass. I have setup Enpass and an extension to my browser Firefox. I can make it operate as long as I am logged into Enpass then the extension shows the required details for the url. Is this how it should work? ie I must be logged into Enpass for the brwser extension works?
Hi oldnewbie,
Yes, you have to open Enpass with your master password for the vault to be available to external applications in your case Firefox.  After that initial opening Enpass itself can be locked, either behind a PIN or master password but as along as it has been opened once you should be good to go.
