Downgrade
I "upgraded" my win8 box to 6.0.6.  It does not sync with my Linux box, which is at 5.something.  I do this using a file on a local server.  Apparently, the sync format has changed, so they do not play with each other. I would think about going to 6.0.6 on the linux side, but the comments here are not encouraging. This is a disaster.   Where do I find a binary to return the windows box to a usable version? Also, how can I export to csv in the 6.0.6 version?  I was good while it lasted.  Thanks.
You can download the previous version of Enpass from this link.
Exporting data in CSV format is already in our roadmap and will be available with the subsequent update.
Thanks!
