April 30, 20197 yr When opening the chrome extension, the view is seemingly zoomed to the point where it is unusable. Chrome version: Version 74.0.3729.108 (Official Build) (64-bit) Macos: 10.14.3 Extension version: 6.0.1 Please see attached screenshot for details.
April 30, 20197 yr Hi, Our dev team is aware of this issue and currently working on it. I appreciate your patience. Thanks.
May 11, 20197 yr On 4/30/2019 at 7:33 AM, Vikram Dabas said: I appreciate your patience. I have exactly the same problem. I paid for Enpass and I wonder how long it will take to solve this problem. For me Enpass is totally useless on my Mac! And sorry but after 11 days my patience has gone
May 15, 20197 yr Hello, I am running Mac OS 10.14.4 on a 2018 MacBook Pro and Enpass 6.0.7. I frequently work connected to an external monitor. When I disconnect from the monitor and use my laptop on it's own, I often find that the graphics for the Enpass password window (accessible by right-clicking in a web form field and selecting "Enpass") is corrupted. Quitting and restarting the application will fix this. But the next time I then connect, or disconnect, essentially changing my video setup, the dialog will usually (80%) be corrupted again. This happened after the last update. I've attached a picture of the dialog as it appears, in this case, I would need to enter my password to continue, and the dialog is corrupted. Thank you
May 15, 20197 yr Hey @Friedi, I can understand that it's irritating when the app doesn't work as expected. The issue has already been resolved, and we’re planning to launch the Beta in the coming weeks. Thanks for your cooperation!
May 19, 20197 yr Author Releasing the beta in the coming weeks? Really? How can your release cadence be in weeks? Is this 2019? Come on guys, if you are marketing this tool as a productivity boost and security mechanism then this issue is to an extent unacceptable. Make a point release, it's likely a touch of css and nothing more.
May 20, 20197 yr On 5/15/2019 at 1:55 PM, Vikram Dabas said: Hey @Friedi, I can understand that it's irritating when the app doesn't work as expected. The issue has already been resolved, and we’re planning to launch the Beta in the coming weeks. Thanks for your cooperation! So, you can understand? I can't understand that we have to wait WEEKS (!) for a BETA!!!
May 20, 20197 yr Hi @Friedi 2 hours ago, Friedi said: So, you can understand? I can't understand that we have to wait WEEKS (!) for a BETA!!! The Beta has already been rolled out. Please check this forum post for more details:
