May 14, 20197 yr Hello, for some sites, since autofill is impossible I would like to disable the automatic connection feature. For some entries I found a checkbox to that purpose but for some others, there is no such checkbox. How should I do to disable automatic connections for specified entries ? Best regards, - Guillaume
May 15, 20197 yr Hi @guizop, Thanks for writing in. I would like to share that the option "Autosubmit Login" is only visible if the particular items have these three fields: Username/Email Password URL So please check and try again. Hope this helps!
June 5, 20197 yr Author Thank you for your answer Anshu actually there is no password since this is a digital 0-9 keyboard used for password for a bank account. nevertheless in such case I would not expect Enpass to attempt autologin in any case :-) I made the checkbox appear. it was unchecked and yet enpass attempts autofill. I thought "automated connection" would not attempt autofill. Was I wrong ? Thank you for your help.
June 7, 20197 yr Hey @guizop, Thanks for writing back. It will be a great help if you can share the URL of the website so that we can proceed further. Thanks!
