May 18, 20197 yr I believe my sync problem on Gdrive is due to two Primary vaults with different names stored on my Gdrive File A for Windows system & File B for Linux drive. I like to merge them into one account so any changes on one computer - automatically will synchronize on another computer. Any suggestion, please.?
May 20, 20197 yr Hey @MLevi, Thanks for writing in. If you want to merge two different Enpass 6 data, please enable sync with the same cloud account on both devices. Hope this helps!
May 20, 20197 yr Author Quote 9 hours ago, Anshu kumar said: Hey @MLevi, Thanks for writing in. If you want to merge two different Enpass 6 data, please enable sync with the same cloud account on both devices. Hope this helps! Anshu thanks for the support. it worked. In regards my earlier problem with syn with Gdrive. I should have installed the enpass on the "User" account - instead the "Admin" one which I did. ( I always create a "User" account" where I do all my activities) The very reason the sync worked on one account and not the other. Best to install enpass with the working (user) account instead of Admin (root)
