June 3, 20197 yr I have recently tried to use Enpass with Opera, owing to my interest in the built-in VPN. The available Enpass extension is loaded, but will not work with the current version of Enpass. Whenever I try to use it it complains that the extension is out of date. Are there plans to update it? Thank you.
June 4, 20197 yr Hey @steveF, Sorry for the trouble you are going through. Please share some more info so that I can help you better. On which device (along with OS version) are you using Enpass? Which Enpass and Enpass extension version are you using? Which Opera version are you using? Are you facing the same problem with other browsers too? Thanks for your co-operation.
June 9, 20196 yr Same problem here. Windows 10 Pro Version 1809 Build 17763.529 Opera Version 60.0.3255.151 Enpass Version 6.1.0 Enpass Extension Version 5.4.3 Any resolution yet? Thanks
June 11, 20196 yr Hi @Rookie, Thanks for your prompt reply and sharing the details. Please install the latest Enpass extension for Opera browser from this link and let me know if the problem persists. Thanks!
June 11, 20196 yr Hi Anshu, Thanks for the response. Uninstalled Enpass then installed Ver 6.0.2. Cannot access Enpass from the browser at all. Right click on any login and the enpass icon is not in the drop down. Left click on the extension icon at the top of the page does nothing. Right click and select Options and the following error show up:
