June 15, 20197 yr My webdav password has changed (due to the password expiry policy) so enpass sync is failing as it is trying to use the old password. so far as to be expected although the error message from Enpass is some obscure error number and could be more helpful (other apps would ask you to re-enter the password in such circumstances). However, I am struggling to work out how to tell Enpass the new password withou having to cancel sync and then reenter all the webdab settings from scratch (which with multiple vaults and devices would be an unacceptably cumbersome process) Matthew p.s. I'm really only usimg webdav as a stop gap whilst waiting for wifi sync to be reinstated. Is there an updated ETA for this? Edited June 15, 20197 yr by mdovey
June 17, 20197 yr Hi @mdovey On 6/15/2019 at 1:57 PM, mdovey said: However, I am struggling to work out how to tell Enpass the new password withou having to cancel sync and then reenter all the webdab settings from scratch (which with multiple vaults and devices would be an unacceptably cumbersome process) Sorry to say but at the moment you have to re-enable the sync from Enpass settings. However, I have noted down your suggestion and forwarded to the concerned desk for further improvement. On 6/15/2019 at 1:57 PM, mdovey said: p.s. I'm really only usimg webdav as a stop gap whilst waiting for wifi sync to be reinstated. Is there an updated ETA for this? The feature of the WiFi sync is already in our top priority list but at the moment I can't assure you any ETA. Thanks!
