June 17, 20197 yr I don't want to lose the popup window of the Enpass Chrome extension when I click on something that isn't the popup window. For example.. I had an Enpass extension for Chrome popup window appear when capturing a new login or update. But I clicked away from the popup window, and the popup windows disappeared. I then lost my login credentials, including the password I just generated. Since the information wasn't captured by Enpass, I had to go through the extra trouble reset my password and start over. I've done this a few times when I've tried to click the main browser window to copy/paste information into the Enpass extension window. Thanks. Chrome Extension v6.0.2
June 18, 20197 yr Hi @jakejohn, Well in this case, please enable Always run assistant in docked mode in Enpass General settings and check. Hope this helps!
