August 1, 20197 yr When I move Enpass into the Chrome menu and then open it, selecting any item selects the corresponding item in the menu beneath it. It makes it difficult to use.
August 2, 20197 yr Hi @andokai We are sorry for the inconvenience caused to you. Unfortunately, from your comment, we could not quite understand what problem you are facing. Please share some more details so that we can assist you better. A screenshot, if possible would be great. Thanks for your co-operation.
August 2, 20197 yr Author Hi @Pratyush Sharma, it's hard to capture in a screenshot so I made a short video clip. It appears to be a problem on macOS only.
