Sync error 908423 (workaround in place)
I just upgraded my Windows 7 version of Enpass desktop to latest proposed upgrade => 6.1.1 (451)
Since then, it cannot sync my main vault on Webdav any longer.
I get error code :908423
Note : I have a secondary safe, also synced via Webdav, but using a slightly different URL, and this one works fine !
What happened ?
What should I do to get my main vault sync back ?
Thanks,
Note : sync on main vault was working perfectly just before the upgrade
I've spend some time investigating further.
This error code is linked to Webdav 423 HTTP error : the file is locked and webdav cannot proceed.
So I turned to my Owncloud server (the Webdav server hosting my vaults), and, despite many attempts to reboot, modify/copy-paste files, reconfigure cache, fsck file system,... I could not succeed in removing the file lock (confirmed in owncloud.log file)
=> I simply gave up and placed my vault in another location on the server (and reconfigured Enpass "main vault" sync URL on each and every device where I use Enpass).
Now it works fine again, but I don't know what happened on Webdav server side (Owncloud).
I still think something went wrong when I upgraded to this latest Enpass version...
  • MisterT changed the title to Sync error 908423 (workaround in place)
  • semi_mod locked this topic
