joby Posted January 15, 2018 Report Posted January 15, 2018 when i input ID&PWD in other apps,enpass can remember what i input, at least,when i use enpass keyboard,it can record。
Guest Akash Vyas Posted January 15, 2018 Report Posted January 15, 2018 Hey @joby Thanks for writing in. If you're using the latest version of Enpass(5.6.4) on a device running Android O (8.0 or above), the OS itself should ask you to save the logins to Enpass when you manually enter the credentials in the app. And if you're using the latest version of Enpass on any earlier versions of Android, Enpass should ask you to save the URL from the app so that you don't have to search for the item when using the Enpass Keyboard. Cheers!
Create an account
Register a new accountSign in
Sign In Now
