August 13, 20197 yr Hello, In previous versions, when the TouchID unlocking was activated when opening, Enpass immediately asked you to put your finger on the button to unlock. Since the last updates, you must first press the logo before you can unlock by TouchID. Would it be possible to add a "unlocking order" in the preferences where you could select TouchID as a priority so that it could be offered immediately. Or select to privilege the master password while leaving TouchID as an option as at present? Thanks to the team !
August 16, 20197 yr Hello @Inkx, Thanks for highlighting this. We understand that the log-in is annoying, and we've considered this feature improvement in our roadmap for future releases. Thanks.
