Slow unlock speed
When entering the password into the browser extension/tray icon version the unlocking is quite slow. It takes about a second until I can search/select an entry and paste it into the input fields.
Is this a limitation of the crypto library or speed of my computer or is it just a visual thing?
If it is just visual I would like to be able to disable that, as it is rather useless and annoying (.2 seconds should be enough, it's obvious that it is unlocked as the entries are shown).
- schrej
Hi @schrej,
Thanks for writing in. Enpass takes a second to play unlock sound and the visual effects. Although I have added a request for faster unlock in our roadmap.
Cheers!
Hi @Anshu kumar,
Thanks!
For me, it would be sufficient to be able to just disable the visuals. The sound could still be played, though, I guess.
Just the slow visuals are quite annoying it just adds a useless second to entering credentials.
- schrej
  • 3 weeks later...
We got used to unlock Windows 10 devices with Hello through pin without any confirm. Enpass would do too
