Keyboard region problem!
Hello,
Im using swedish as my display language of windows 10 and a swedish keyboard.
I was getting frustrated because everytime i was setting up a OneDrive sync it worked on that device but not on the other one (win 10 pc / mobile).
I got the wrong master password each time and couldnt figure out what was wrong...
Until i found another thread here that found out that it could be the region setting of the keyboard thats messing this up.
I tried to use a simple password without any special characters and that works!
Can you please fix this keyboard region bug, i cant have a password manager which i cant use a advanced master password on :/
Hi @Ted
Sorry to hear about your trouble. Please let me know which Enpass version are you using on the both devices also please type your master password ( when master password doesn't work) in notepad and check whether you are typing the same password in both devices.
  • 1 month later...
Hi @Anshu kumar
I have the latest version of Enpass on both my W10 computer and my Lumia 1520 running the latest W10 insider version.
When i create the enpass archive on my computer with OneDrive sync i used notepad to type the password i wanted and the copy/paste it into the master password field.
When i synced the enpass file on my Lumia 1520 i can write the password with the on screen keyboard.
But when i try to write the correct master password on my computer i get wrong password, but if i write it in Notepad and use copy/paste it works without any problem.
This seems to be a keyboard region problem in the master password field since i can copy/paste the correct password but not to write it with my Swedish keyboard layout.
Hi @Ted,
Thanks for getting back. Please follow these steps and let me know does your problem gets resolved?
Go to Device Settings --> Open Region & language --> Remove all other languages except (Swedish keyboard) and now check if it helps.
