August 27, 20197 yr Debian 10 with gnome. The problem is present in wayland and Xorg. env | grep QT QT_ACCESSIBILITY=1 QT_SCREEN_SCALE_FACTORS=1.2 QT_AUTO_SCREEN_SCALE_FACTOR=0 QT_SCALE_FACTOR=1.2 I tried export QSG_RENDER_LOOP=basic export QT_OPENGL=software /opt/enpass/Enpass The problem persists.
August 28, 20197 yr Hi @lebfr, Thanks for reporting this issue and we are sorry for the inconvenience caused to you. I have noted down this issue in the tracker and notified the QA team to look into it. I will get back to you soon. Thanks for your co-operation.
August 29, 20197 yr Hey @lebfr, I would suggest you to set the values of QT_SCALE_FACTOR and QT_SCREEN_SCALE_FACTORS either to 1 or 2 and don't use any fraction number. Hope this helps!
August 29, 20197 yr Author @Anshu kumar It helped. I can't use this solution. If the values are specified 1 or 2, the application is too small or too large.
August 29, 20197 yr Hey @lebfr, Thanks for your prompt reply. Well, will look into this to find how can we do it. Thanks for your co-operation.
October 4, 20206 yr Any update here? On my 1440p monitor Enpass is displayed to small so I set QT_SCALE_FACTOR=1.25. But this produces visual glitches. Especially when/after scrolling or dragging. Like the OP said, setting "1" is to small, setting "2" is to big. But "1.25" produces this: System: Win 10, 2004 Edited October 4, 20206 yr by Monk32
October 6, 20206 yr Hey @Monk32 Sorry for the trouble. Thanks for your reporting this issue. We have identified the issue at our end too and we'll work to fix it so it runs as expected.
