September 6, 20197 yr On PC, you can restore backup for any date. But on the mobile I can’t find the backup recovery option.
September 6, 20197 yr In v6 'Restore' option appears only in two scenarios: 1. When the app is newly/freshly installed. 2. Creating a new vault. (The app is already installed and contains database).
October 25, 20197 yr So can I update my current vault on mobile from a backup file created on my PC? I used to on earlier releases (using wifi !!)
October 30, 20197 yr Hi @Punk Funk, You need to create a new vault so as to restore the backup file into it and all the data from that file will be present in your newly created vault.
November 5, 20197 yr Thanks for this information. Use these free gas cards in 2020. Edited November 29, 20196 yr by Davidjames3321
December 6, 20196 yr When i start a backup on wifi it takes too long to complete. It get's stuck at 97%. I resloved it with the help of this guide. It's helpful. Edited December 27, 20196 yr by samjonas
