Crash on delete fields
I've been using Enpass for several weeks now, and I really love it. Today I've finally decided to move from Padlock.io to Enpass. I've imported all my data from csv file. I loved the csv import, really useful.
Furthermore, I'm having some issues. If I open an item and I delete a field and save, the app crashses.
I'm also having another problem. In some items, if I try to edit a field, the field that is edited is another one. For example, suppose I have field_1 and field_2. Then I select to edit field_1, but the editing popup says that I'm editing field_2 and if I change the field type to password, its only changed in field_2. If I select to edit field_2, the popup says correctly that I'm editing field_2.
I'm really disappointed to this because I was convinced to move to Enpass and I wanted to buy the mobile version rather than SafeInCloud that looks promising too.
Hope you can help me and I can keep using Enpass rather than other services.
Eduard
Edited by Eduard Bosch
Add tag
Hi @Eduard Bosch,
First of all, I would like to thank you for choosing Enpass!
I am really very sorry that you are facing these issues and I can also understand the level of frustration. This sound very weird as neither we have never faced it here and nor reported by any customer so far. For investigation purpose, please provide some more details.
  • On which device (along with OS version) are you using Enpass?
  • From which PadLock version have you imported your data?
  • Did you import using Generic CSV/DSV or option to import directly from for Password PadLock?
  • Does this issue appear if you try to edit any item created by Enpass rather than the one imported from Password Padlock?
All this information will help us understanding if the problem is there in data imported using the Password padlock.
Thanks!
Hi @Anshu kumar,
Quote
Macbook Pro Early 2013
macOS Sierra 10.12.3 Beta (16D17a)
Quote
Enpass 5.4.1 (74)
Quote
Padlock 1.2.0-beta.2 (1.2.0-beta.2)
Quote
Generic CSV/DSV. I haven't found the "Pasword PadLock". Now I realice it was an option.
Quote
Only appear for passwords imported. With the ones that I've created, everything works fine.
The crash happens when I delete a field and then I select another field to edit (I select the name of the field to edit, not the content).
I wanted to attach you a log file, but forum only allows pictures as attachments. I post the log as code:
Process:               Enpass [8348]
Path:                  /Applications/Enpass.app/Contents/MacOS/Enpass
Identifier:            in.sinew.Enpass-Desktop
Version:               5.4.1 (74)
App Item ID:           732710998
App External ID:       820392960
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Enpass [8348]
User ID:               501
Date/Time:             2017-01-22 21:46:06.248 +0100
OS Version:            Mac OS X 10.12.3 (16D17a)
Report Version:        12
Anonymous UUID:        CE774050-55DB-5653-6748-E769B486C4AB
Sleep/Wake UUID:       FE1E744F-BC62-487C-A007-7D4A4F282289
Time Awake Since Boot: 22000 seconds
Time Since Wake:       10000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000020
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [0]
VM Regions Near 0x20:
    __TEXT                 000000010e121000-000000010e94c000 [ 8364K] r-x/rwx SM=COW  /Applications/Enpass.app/Contents/MacOS/Enpass
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   in.sinew.Enpass-Desktop       	0x000000010e146384 0x10e121000 + 152452
1   in.sinew.Enpass-Desktop       	0x000000010e282a77 0x10e121000 + 1448567
2   org.qt-project.QtCore         	0x000000010fa00ebc QMetaObject::activate(QObject*, int, int, void**) + 876
3   org.qt-project.QtWidgets      	0x000000010ec8e36c 0x10eb90000 + 1041260
4   org.qt-project.QtWidgets      	0x000000010ec8e2df 0x10eb90000 + 1041119
5   org.qt-project.QtWidgets      	0x000000010ec8f36e QAbstractButton::mouseReleaseEvent(QMouseEvent*) + 270
6   org.qt-project.QtWidgets      	0x000000010ebe2cb1 QWidget::event(QEvent*) + 1681
7   org.qt-project.QtWidgets      	0x000000010ec8f0bf QAbstractButton::event(QEvent*) + 175
8   org.qt-project.QtWidgets      	0x000000010eba1956 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 294
9   org.qt-project.QtWidgets      	0x000000010eba522d QApplication::notify(QObject*, QEvent*) + 9549
10  org.qt-project.QtCore         	0x000000010f9cdc84 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 164
11  org.qt-project.QtWidgets      	0x000000010eba2328 QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) + 968
12  org.qt-project.QtWidgets      	0x000000010ec04577 0x10eb90000 + 476535
13  org.qt-project.QtWidgets      	0x000000010ec03561 0x10eb90000 + 472417
14  org.qt-project.QtWidgets      	0x000000010eba1956 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 294
15  org.qt-project.QtWidgets      	0x000000010eba4415 QApplication::notify(QObject*, QEvent*) + 5941
16  org.qt-project.QtCore         	0x000000010f9cdc84 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 164
17  org.qt-project.QtGui          	0x000000010f22ef4a QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 2794
18  org.qt-project.QtGui          	0x000000010f21815b QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 155
19  libqcocoa.dylib               	0x000000011202b461 0x112008000 + 144481
20  com.apple.CoreFoundation      	0x00007fff8e8938d1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
21  com.apple.CoreFoundation      	0x00007fff8e874c6c __CFRunLoopDoSources0 + 556
22  com.apple.CoreFoundation      	0x00007fff8e874156 __CFRunLoopRun + 934
23  com.apple.CoreFoundation      	0x00007fff8e873b54 CFRunLoopRunSpecific + 420
24  com.apple.HIToolbox           	0x00007fff8ddfeacc RunCurrentEventLoopInMode + 240
25  com.apple.HIToolbox           	0x00007fff8ddfe809 ReceiveNextEventCommon + 184
26  com.apple.HIToolbox           	0x00007fff8ddfe736 _BlockUntilNextEventMatchingListInModeWithFilter + 71
27  com.apple.AppKit              	0x00007fff8c3a4abc _DPSNextEvent + 1120
28  com.apple.AppKit              	0x00007fff8cb1f1f7 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2789
29  com.apple.AppKit              	0x00007fff8c5fad54 -[NSApplication _doModalLoop:peek:] + 497
30  com.apple.AppKit              	0x00007fff8c7dbbf4 __33-[NSApplication runModalSession:]_block_invoke + 80
31  com.apple.AppKit              	0x00007fff8c7dbac4 -[NSApplication runModalSession:] + 137
32  libqcocoa.dylib               	0x000000011202a28a 0x112008000 + 139914
33  org.qt-project.QtCore         	0x000000010f9ca051 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 401
34  org.qt-project.QtCore         	0x000000010f9ce2f5 QCoreApplication::exec() + 341
35  in.sinew.Enpass-Desktop       	0x000000010e1cb755 0x10e121000 + 698197
36  libdyld.dylib                 	0x00007fffa3e6c255 start + 1
Thread 1:: Qt bearer thread
0   libsystem_kernel.dylib        	0x00007fffa3f9ac0e __pselect + 10
1   libsystem_kernel.dylib        	0x00007fffa3f97811 pselect$1050 + 82
2   org.qt-project.QtCore         	0x000000010fa21d57 qt_safe_select(int, fd_set*, fd_set*, fd_set*, timespec const*) + 103
3   org.qt-project.QtCore         	0x000000010fa22e25 QEventDispatcherUNIXPrivate::doSelect(QFlags<QEventLoop::ProcessEventsFlag>, timespec*) + 693
4   org.qt-project.QtCore         	0x000000010fa23fc7 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 231
5   org.qt-project.QtCore         	0x000000010f9ca051 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 401
6   org.qt-project.QtCore         	0x000000010f80f0ee QThread::exec() + 110
7   org.qt-project.QtCore         	0x000000010f812b5a 0x10f7ea000 + 166746
8   libsystem_pthread.dylib       	0x00007fffa4083aab _pthread_body + 180
9   libsystem_pthread.dylib       	0x00007fffa40839f7 _pthread_start + 286
10  libsystem_pthread.dylib       	0x00007fffa40831fd thread_start + 13
Thread 2:
0   libsystem_kernel.dylib        	0x00007fffa3f9338a mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x00007fffa3f927d7 mach_msg + 55
2   coop.plausible.CrashReporter  	0x00000001106202a8 exception_server_thread + 202
3   libsystem_pthread.dylib       	0x00007fffa4083aab _pthread_body + 180
4   libsystem_pthread.dylib       	0x00007fffa40839f7 _pthread_start + 286
5   libsystem_pthread.dylib       	0x00007fffa40831fd thread_start + 13
Thread 3:: com.apple.CFSocket.private
0   libsystem_kernel.dylib        	0x00007fffa3f9af4a __select + 10
1   com.apple.CoreFoundation      	0x00007fff8e8b0239 __CFSocketManager + 729
2   libsystem_pthread.dylib       	0x00007fffa4083aab _pthread_body + 180
3   libsystem_pthread.dylib       	0x00007fffa40839f7 _pthread_start + 286
4   libsystem_pthread.dylib       	0x00007fffa40831fd thread_start + 13
Thread 4:: Qt HTTP thread
1   org.qt-project.QtCore         	0x000000010fa21f13 qt_safe_select(int, fd_set*, fd_set*, fd_set*, timespec const*) + 547
2   org.qt-project.QtCore         	0x000000010fa22e25 QEventDispatcherUNIXPrivate::doSelect(QFlags<QEventLoop::ProcessEventsFlag>, timespec*) + 693
3   org.qt-project.QtCore         	0x000000010fa23fc7 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 231
4   org.qt-project.QtCore         	0x000000010f9ca051 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 401
5   org.qt-project.QtCore         	0x000000010f80f0ee QThread::exec() + 110
6   org.qt-project.QtCore         	0x000000010f812b5a 0x10f7ea000 + 166746
7   libsystem_pthread.dylib       	0x00007fffa4083aab _pthread_body + 180
8   libsystem_pthread.dylib       	0x00007fffa40839f7 _pthread_start + 286
9   libsystem_pthread.dylib       	0x00007fffa40831fd thread_start + 13
Thread 5:: com.apple.NSEventThread
2   com.apple.CoreFoundation      	0x00007fff8e874e84 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation      	0x00007fff8e874301 __CFRunLoopRun + 1361
4   com.apple.CoreFoundation      	0x00007fff8e873b54 CFRunLoopRunSpecific + 420
5   com.apple.AppKit              	0x00007fff8c4f1f6a _NSEventThread + 205
6   libsystem_pthread.dylib       	0x00007fffa4083aab _pthread_body + 180
7   libsystem_pthread.dylib       	0x00007fffa40839f7 _pthread_start + 286
8   libsystem_pthread.dylib       	0x00007fffa40831fd thread_start + 13
Thread 6:: com.apple.NSURLConnectionLoader
5   com.apple.CFNetwork           	0x00007fff8d9e2680 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
6   com.apple.Foundation          	0x00007fff902b5c6d __NSThread__start__ + 1243
Thread 7:: Qt HTTP thread
Thread 8:: Qt HTTP thread
Thread 9:
0   libsystem_kernel.dylib        	0x00007fffa3f9b4e2 __workq_kernreturn + 10
1   libsystem_pthread.dylib       	0x00007fffa40835fe _pthread_wqthread + 1023
2   libsystem_pthread.dylib       	0x00007fffa40831ed start_wqthread + 13
Thread 10:
1   libsystem_pthread.dylib       	0x00007fffa4083791 _pthread_wqthread + 1426
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000002  rbx: 0x0000000000000000  rcx: 0x00007fff51adc168  rdx: 0x0000000000000001
  rdi: 0x00007fff51adc160  rsi: 0x0000000000000000  rbp: 0x00007fff51adc100  rsp: 0x00007fff51adc100
   r8: 0x00000000ffffffff   r9: 0x000000000000003f  r10: 0x000000011215b958  r11: 0x00007faeb03379b0
  r12: 0x00006080001db7b0  r13: 0x0000610000a40c30  r14: 0x00007fff51adc170  r15: 0x0000000000000000
  rip: 0x000000010e146384  rfl: 0x0000000000010202  cr2: 0x0000000000000020
Logical CPU:     2
Error Code:      0x00000004
Trap Number:     14
Binary Images:
       0x10e121000 -        0x10e94bff7 +in.sinew.Enpass-Desktop (5.4.1 - 74) <9A236BE7-F593-37C3-B821-1D1132CFC3B4> /Applications/Enpass.app/Contents/MacOS/Enpass
       0x10e9fc000 -        0x10eb16fdf +libcrypto.1.0.0.dylib (0) <6A60BC71-F7DB-37A5-96EA-74BD4762E2DC> /Applications/Enpass.app/Contents/Frameworks/libcrypto.1.0.0.dylib
       0x10eb90000 -        0x10f091fff +org.qt-project.QtWidgets (5.6 - 5.6.2) <55CD5FA6-8E07-3D38-95DA-F7719D0B6500> /Applications/Enpass.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
       0x10f207000 -        0x10f6e8ff7 +org.qt-project.QtGui (5.6 - 5.6.2) <3A1CC6E3-2B51-307A-B556-7297C89B09CE> /Applications/Enpass.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui
       0x10f7ea000 -        0x10fd04ff7 +org.qt-project.QtCore (5.6 - 5.6.2) <91E950DC-8849-3BB9-BBAC-83A53F7B29C2> /Applications/Enpass.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
       0x10fdcd000 -        0x10fe61fe7 +org.qt-project.QtMultimedia (5.6 - 5.6.2) <BB25B1BB-0B0C-3B45-BE5C-CCF970E26054> /Applications/Enpass.app/Contents/Frameworks/QtMultimedia.framework/Versions/5/QtMultimedia
       0x10feb8000 -        0x10ffc0ff7 +org.qt-project.QtNetwork (5.6 - 5.6.2) <8C2A6AF5-4A99-3143-9E5C-C897EB3E0FC3> /Applications/Enpass.app/Contents/Frameworks/QtNetwork.framework/Versions/5/QtNetwork
       0x11000d000 -        0x110046fff +net.hockeyapp.sdk.mac (3.0 - 27) <552B57DE-E183-3820-9DAD-0A254F39187A> /Applications/Enpass.app/Contents/Frameworks/HockeySDK.framework/Versions/A/HockeySDK
       0x11008a000 -        0x110093ff7 +org.qt-project.QtMacExtras (5.6 - 5.6.2) <C1009206-580E-30A0-AE66-02F26EFC77E2> /Applications/Enpass.app/Contents/Frameworks/QtMacExtras.framework/Versions/5/QtMacExtras
       0x1100a0000 -        0x1100d4fff +org.qt-project.QtXml (5.6 - 5.6.2) <B2EA06F8-1A88-3A97-9E64-EB180865AD0A> /Applications/Enpass.app/Contents/Frameworks/QtXml.framework/Versions/5/QtXml
       0x1100ed000 -        0x110118fff +org.qt-project.QtSql (5.6 - 5.6.2) <C0D72ED4-5822-3C8E-8563-29DD06EA98F6> /Applications/Enpass.app/Contents/Frameworks/QtSql.framework/Versions/5/QtSql
       0x110135000 -        0x11056aff7 +org.qt-project.QtXmlPatterns (5.6 - 5.6.2) <6E8A6884-4B67-3AE8-B48B-6A425DEBA5FC> /Applications/Enpass.app/Contents/Frameworks/QtXmlPatterns.framework/Versions/5/QtXmlPatterns
       0x1105ca000 -        0x1105e9fff +org.qt-project.QtWebSockets (5.6 - 5.6.2) <7C3F341C-DAEE-3003-A467-F4BD7222BBA5> /Applications/Enpass.app/Contents/Frameworks/QtWebSockets.framework/Versions/5/QtWebSockets
       0x110601000 -        0x110605ffb  com.apple.agl (3.3.1 - AGL-3.3.1) <E4A1E7B9-9C37-3244-8415-F0F028CB2859> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
       0x110610000 -        0x110639ff7 +coop.plausible.CrashReporter (1.0) <037FC6FA-6FB2-3584-9DD0-145D468013C9> /Applications/Enpass.app/Contents/Frameworks/HockeySDK.framework/Versions/A/Frameworks/CrashReporter.framework/Versions/A/CrashReporter
       0x112008000 -        0x112148fff +libqcocoa.dylib (0) <91E8903F-7510-32E1-87C8-09E1C520DF0A> /Applications/Enpass.app/Contents/PlugIns/platforms/libqcocoa.dylib
       0x112192000 -        0x1121c6ff7 +org.qt-project.QtPrintSupport (5.6 - 5.6.2) <1DF43F58-29BC-33FA-BE2B-C5DC509E4CD6> /Applications/Enpass.app/Contents/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport
       0x1149b7000 -        0x1149bbff7 +libqtga.dylib (0) <E1CA2E71-F46B-3C57-B463-93B69AE4A5B5> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqtga.dylib
       0x114e1b000 -        0x114e22ff7 +libqgif.dylib (0) <B996C87F-E3D4-34E9-B1A6-A8FCADC7D166> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqgif.dylib
       0x114e30000 -        0x1152ecff7  com.apple.driver.AppleIntelHD4000GraphicsGLDriver (10.22.27 - 10.2.2) <0BF13EE9-CD3F-3FD3-8778-CDE631C44E6C> /System/Library/Extensions/AppleIntelHD4000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsGLDriver
       0x1154ea000 -        0x11555bfff  com.apple.driver.AppleIntelHD4000GraphicsMTLDriver (10.22.27 - 10.2.2) <199C6D8A-C1E1-3073-A834-1890DDA38C0E> /System/Library/Extensions/AppleIntelHD4000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsMTLDriver
       0x1156a7000 -        0x1156b1ff7 +libqdds.dylib (0) <BB929006-6D4B-371D-9879-828050774335> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqdds.dylib
       0x1159c8000 -        0x1159d0fff +libqicns.dylib (0) <F32D120B-B6EC-3A24-869B-C03B0609F36A> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqicns.dylib
       0x1159d8000 -        0x1159defff +libqico.dylib (0) <D5882C6A-2180-3EDF-89AD-52397DCE9BC4> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqico.dylib
       0x1159e5000 -        0x115a24fff +libqjpeg.dylib (0) <807D4579-0806-3397-B44E-43B50875A9E9> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqjpeg.dylib
       0x115a2e000 -        0x115a92fff +libqtiff.dylib (0) <BEB9A7E2-95BA-3A5E-99F4-44B5C7EC75A8> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqtiff.dylib
       0x115a9e000 -        0x115aa2ff7 +libqwbmp.dylib (0) <68726B50-5BCE-3506-BD61-D326A6F759A5> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqwbmp.dylib
       0x115aa9000 -        0x115b0cff7 +libqwebp.dylib (0) <498CD8E7-32DF-3447-884F-94EA2820D2E3> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqwebp.dylib
       0x115b57000 -        0x115b60fff +libqgenericbearer.dylib (0) <A71EC345-9E6C-36CD-90ED-5C277DC4F6B0> /Applications/Enpass.app/Contents/PlugIns/bearer/libqgenericbearer.dylib
       0x115c3f000 -        0x115c7c267  dyld (421.2) <947FC440-80F9-32F7-A773-6FC418FE1AB7> /usr/lib/dyld
       0x1161ee000 -        0x11620afff  com.apple.security.csparser (3.0 - 57740.31.2) <4B5D9DDE-2815-3084-AEC0-8B630279732F> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
       0x117391000 -        0x117392ff1 +cl_kernels (???) <ED81C1A1-2170-4259-AE3C-D123FD13240A> cl_kernels
       0x1176c1000 -        0x1177c9fff +libqsqlite.dylib (0) <C2DE9276-4D22-38F3-9039-F5AA56A67E0C> /Applications/Enpass.app/Contents/PlugIns/sqldrivers/libqsqlite.dylib
       0x118248000 -        0x11824cfff  com.apple.audio.AppleHDAHALPlugIn (278.56 - 278.56) <CDA14261-23B7-30CD-B27B-1459F5C70F9D> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
       0x11825d000 -        0x11825eff3 +cl_kernels (???) <A48AA9A7-1A03-4BD5-A9E0-ED210BA5E2AC> cl_kernels
       0x118fc0000 -        0x118fc9ff7 +libqsqlcipher.dylib (0) <119F2326-3F48-3902-83C7-09543DEA2526> /Applications/Enpass.app/Contents/PlugIns/sqldrivers/libqsqlcipher.dylib
       0x118fd3000 -        0x118fe5ff7 +libqtaudio_coreaudio.dylib (0) <5F3432F7-86A1-3918-8BF1-9BCF3E6FC895> /Applications/Enpass.app/Contents/PlugIns/audio/libqtaudio_coreaudio.dylib
       0x118fee000 -        0x118ff4fff +com.prosofteng.soundbunny.plugin (1.0.3 - 1131.19.23) <ACFF51B7-4735-3674-A8BA-DD8104A1FB71> /Library/Audio/Plug-Ins/HAL/SoundBunny.plugin/Contents/MacOS/SoundBunny
       0x119189000 -        0x11923cfff +libsqlcipher.0.dylib (0) <EEA8B2A1-377D-3588-927B-ACF0815B1D81> /Applications/Enpass.app/Contents/Frameworks/libsqlcipher.0.dylib
       0x11936b000 -        0x11936ffff  libFontRegistryUI.dylib (196.3) <FA631B39-8678-372D-B320-FD2DAD848DD6> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
       0x119682000 -        0x1197ecfff  com.apple.audio.units.Components (1.14 - 1.14) <0D9761F5-DEAB-327E-97C4-5213119D4A86> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
    0x7fff8938a000 -     0x7fff896c3fff  com.apple.RawCamera.bundle (7.01 - 889) <155ED09B-673E-3726-8302-E54AADAC5B63> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fff89cc7000 -     0x7fff8a513fff  com.apple.GeForceGLDriver (10.14.20 - 10.1.4) <4A117948-86A8-3F73-8924-E83ACE8097DD> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
    0x7fff8a514000 -     0x7fff8ade2ff3  libclh.dylib (4.0.3 - 4.0.3) <8E5184E5-E35E-3A6C-91FF-4933C349B3EB> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
    0x7fff8ade3000 -     0x7fff8aef3ff7  com.apple.GeForceMTLDriver (10.14.20 - 10.1.4) <F2438C2D-0DF4-35D6-BD4D-5A8551038779> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
    0x7fff8aef4000 -     0x7fff8b0b3ffb  com.apple.avfoundation (2.0 - 1187.11.13) <2EB63F2D-32A1-3196-AE4C-6B0C3A142721> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fff8b0b4000 -     0x7fff8b157fff  com.apple.audio.AVFAudio (1.0 - ???) <3A8910D2-9EDC-3879-B1EC-E32149410F4C> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
    0x7fff8b220000 -     0x7fff8b220fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <BDDB2053-BB24-34E4-A452-50D1260BF672> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff8b221000 -     0x7fff8b238ff3  libCGInterfaces.dylib (331.5) <4E2DCEFA-F243-3FAE-8BFC-0B349973DD14> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff8b239000 -     0x7fff8b879fe3  com.apple.vImage (8.1 - ???) <77F96C96-725E-31E5-8072-D09C6BD988A2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff8b87a000 -     0x7fff8ba41fef  libBLAS.dylib (1185) <0D55CF73-6DBD-3D15-B500-189479638551> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff8ba42000 -     0x7fff8ba59fff  libBNNS.dylib (14) <43A9B06E-3C21-3CE6-B0C1-99DA172DEEB0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fff8ba5a000 -     0x7fff8be65fff  libLAPACK.dylib (1185) <E7AE9C48-6E42-3EB7-A257-D48E0CB48D00> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff8be66000 -     0x7fff8be7cfff  libLinearAlgebra.dylib (1185) <08F00EFB-B477-3421-906E-3D364E607E6A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff8be7d000 -     0x7fff8be83fff  libQuadrature.dylib (3) <120F6228-A3D4-3184-89D7-785ADC2AC715> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fff8be84000 -     0x7fff8be97ff7  libSparseBLAS.dylib (1185) <912E3D25-27C0-3245-B64C-3CAD43A5D633> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff8be98000 -     0x7fff8bfe5ff7  libvDSP.dylib (600) <87EF1D0A-1F85-31DD-AD8F-AB31E7D8E73B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff8bfe6000 -     0x7fff8c09dfff  libvMisc.dylib (600) <F6EA539E-0A90-3F8A-9ECA-001E46394E29> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff8c09e000 -     0x7fff8c09efff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <B4B785D8-CB43-3E5D-AE81-1F27885AA112> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff8c35e000 -     0x7fff8d12fff7  com.apple.AppKit (6.9 - 1504.77) <449FD004-0E4C-3E26-8F29-B2A10F98D8B5> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff8d141000 -     0x7fff8d141fff  com.apple.ApplicationServices (48 - 48) <A29F0B74-33C1-3062-B68D-12BC3881C399> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff8d142000 -     0x7fff8d1b0ff7  com.apple.ApplicationServices.ATS (377 - 422.2) <3680281F-DB99-3CA2-9C76-CABFC8DBC980> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff8d24a000 -     0x7fff8d379fff  libFontParser.dylib (194.6) <F3DF2CF7-B25D-30BB-9EE6-1EA9F3B8A066> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff8d37a000 -     0x7fff8d3c4fff  libFontRegistry.dylib (196.3) <855AF921-EAE0-3D07-B161-5EF09806B643> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff8d421000 -     0x7fff8d454ff7  libTrueTypeScaler.dylib (194.6) <D0D7DA50-DF52-3D24-AFD2-03B336AA1929> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fff8d4c0000 -     0x7fff8d56aff7  com.apple.ColorSync (4.12.0 - 502.1) <5F244DE3-A6E8-335F-AE3B-25F0E407DD62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff8d56b000 -     0x7fff8d5bbff7  com.apple.HIServices (1.22 - 591) <34C950CC-1084-354A-BCE6-9396EDB29DF8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff8d5bc000 -     0x7fff8d5cbff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <47D1A017-91A4-37F3-93E0-3923CD6ED2DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff8d5cc000 -     0x7fff8d619fff  com.apple.print.framework.PrintCore (12 - 491) <B7CC15C1-AF50-37F3-8AF6-65F8CDC323F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff8d61a000 -     0x7fff8d655fff  com.apple.QD (3.12 - 310) <8F718290-DD82-36CE-9AF0-EFB6D31A49F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff8d656000 -     0x7fff8d661ff7  com.apple.speech.synthesis.framework (6.3.3 - 6.3.3) <629831B1-B13C-30F5-AE16-6BB9037E3753> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff8d662000 -     0x7fff8d872fff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <0C739FDF-3BED-3B27-B0B6-9A00F11A865D> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff8d873000 -     0x7fff8d873fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <339D3E17-CF4C-3E44-BECF-EDB3B78283C5> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff8d9dc000 -     0x7fff8ddafff7  com.apple.CFNetwork (807.2.14 - 807.2.14) <9702C8B9-2984-3DD9-9C59-A83499C2DBC4> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff8ddc9000 -     0x7fff8ddc9fff  com.apple.Carbon (154 - 157) <E7179C37-54BF-3DAC-BD4A-ABCCBBDFDDAE> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff8ddca000 -     0x7fff8ddcdfff  com.apple.CommonPanels (1.2.6 - 98) <6A71E8CB-3BF7-3A49-A5F7-0579BAE1219D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff8ddce000 -     0x7fff8e0d6ff7  com.apple.HIToolbox (2.1.1 - 856.11) <11F1BAA6-547C-37CB-88DE-6C4B698AFF37> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff8e0d7000 -     0x7fff8e0daff7  com.apple.help (1.3.5 - 49) <27C5F9FE-838F-3807-A4AC-D99470185B10> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff8e0db000 -     0x7fff8e0e0fff  com.apple.ImageCapture (9.0 - 9.0) <E3E757FD-4060-33A4-A2AC-85EFBD987FCE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff8e0e1000 -     0x7fff8e178ff3  com.apple.ink.framework (10.9 - 219) <B44BA36D-7549-3EB2-8CF6-E171885194FB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff8e179000 -     0x7fff8e193fff  com.apple.openscripting (1.7 - 172) <B204BF70-C4AA-3699-8493-66E6645A92A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff8e194000 -     0x7fff8e195ff3  com.apple.print.framework.Print (12 - 267) <CA7E9448-0903-34C8-AAF6-9070B52BF70E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff8e196000 -     0x7fff8e198ff7  com.apple.securityhi (9.0 - 55006) <ACD20DC1-FBDE-3E1B-91BF-867FE7849CBC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff8e199000 -     0x7fff8e19fff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <A20B0F7B-C32A-3FF1-BB75-BAC0EE4EF889> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff8e1a0000 -     0x7fff8e27dff7  com.apple.cloudkit.CloudKit (643.5 - 643.5) <2AB1D950-7EA5-359C-B17C-42AEFE99D360> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fff8e27e000 -     0x7fff8e27efff  com.apple.Cocoa (6.11 - 22) <E1579646-9985-3453-B39C-A266D45F165F> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff8e3be000 -     0x7fff8e44eff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <8E3F320B-DA8F-3F9C-B930-190B46834BFD> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff8e44f000 -     0x7fff8e462fff  com.apple.CoreBluetooth (1.0 - 1) <76AFC4B4-A9FD-3434-B168-90087E71F5C4> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff8e463000 -     0x7fff8e761fff  com.apple.CoreData (120 - 752.8) <694F9EA9-A785-3F84-8EB1-DAF76E3BDF9B> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff8e762000 -     0x7fff8e7eefff  com.apple.CoreDisplay (1.0 - 1) <48B568C0-1E12-34F4-943D-EAB447FBA1BE> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff8e7ef000 -     0x7fff8ec83ff7  com.apple.CoreFoundation (6.9 - 1348.28) <0F1FAA52-1C06-327E-A170-382B48B1846D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff8ec84000 -     0x7fff8f327ff7  com.apple.CoreGraphics (2.0 - 1070.13) <D3D3755B-A2AF-3408-86C1-CAD1114586D0> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff8f328000 -     0x7fff8f56afff  com.apple.CoreImage (12.2.0 - 451.2.6) <C390714C-0BE3-3CA6-A7E1-D5DA914112B9> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff8f56b000 -     0x7fff8f5d1ff7  com.apple.corelocation (2100.5.34) <64E3F80C-E0FC-309D-B70D-0D0EC002CA70> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fff8f5d2000 -     0x7fff8f682fff  com.apple.CoreMedia (1.0 - 1907.15.15) <44BCCA20-9202-355A-9E7F-B529BCB81DAD> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff8f683000 -     0x7fff8f6cefff  com.apple.CoreMediaIO (803.0 - 4928.1) <D696CEDB-8576-32DA-8713-2A3745422DCD> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fff8f6cf000 -     0x7fff8f6cffff  com.apple.CoreServices (775.9.7 - 775.9.7) <A5C444F3-408B-3062-AF4B-BF8CD919F221> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff8f6d0000 -     0x7fff8f721fff  com.apple.AE (712.2 - 712.2) <342A13C0-4A6A-3947-B66B-0F624A4A7B52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff8f722000 -     0x7fff8f9fdff7  com.apple.CoreServices.CarbonCore (1159.5 - 1159.5) <11CC2194-0C9C-397A-B7F9-CDAB9B68D87D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff8f9fe000 -     0x7fff8fa31fff  com.apple.DictionaryServices (1.2 - 274) <864F3808-FFDD-3C4B-A5B7-F1A6C4668A86> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff8fa32000 -     0x7fff8fa3affb  com.apple.CoreServices.FSEvents (1230 - 1230) <13A2FC17-8F8C-35BF-9584-59FDFB738E2B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff8fa3b000 -     0x7fff8fba6ffb  com.apple.LaunchServices (775.9.7 - 775.9.7) <40748A55-D932-3527-957A-2E9A96287175> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff8fba7000 -     0x7fff8fc57fff  com.apple.Metadata (10.7.0 - 1075.28) <DBB524CD-6938-3623-99C2-4B1EC1E1BE58> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff8fc58000 -     0x7fff8fcb7fff  com.apple.CoreServices.OSServices (775.9.7 - 775.9.7) <F9973183-F193-3586-9C10-5787B51BC01F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff8fcb8000 -     0x7fff8fd28fff  com.apple.SearchKit (1.4.0 - 1.4.0) <F1B3EF8D-E820-317C-AC7F-8F056C246874> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff8fd29000 -     0x7fff8fd6fff7  com.apple.coreservices.SharedFileList (38 - 38) <E1400999-1F08-35A1-9D07-27D80A2AF89A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff8fdfc000 -     0x7fff8ff48ff7  com.apple.CoreText (352.0 - 544.5) <E90EA1D8-3491-3014-9043-9928C4E4349C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff8ff49000 -     0x7fff8ff7efff  com.apple.CoreVideo (1.8 - 234.0) <48C31E93-87C2-31F4-97E7-9E54C1EA8E7D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff8ff7f000 -     0x7fff8fff0ffb  com.apple.framework.CoreWLAN (11.0 - 1200.25.1) <BEBE9C03-3B9A-3948-99E3-CC8148FA2AB5> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff900ef000 -     0x7fff900f4fff  com.apple.DiskArbitration (2.7 - 2.7) <16EA6D93-A2EC-31DB-BF52-C4764E7B1630> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff90283000 -     0x7fff9062aff3  com.apple.Foundation (6.9 - 1349.25) <D820A498-2E62-367D-BC72-5845B14C06E3> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff90656000 -     0x7fff90687fff  com.apple.GSS (4.0 - 2.0) <95FAD1F9-1610-3428-B9B4-D32F67C26574> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff90747000 -     0x7fff907eaffb  com.apple.Bluetooth (5.0.3 - 5.0.3f1) <CCB4E097-1ED0-3439-8450-2B6EFFBC4608> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff907eb000 -     0x7fff90880ff7  com.apple.framework.IOKit (2.0.2 - 1324.30.13) <EED18749-5DC8-3BC2-AB51-E153E22BC0DA> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff90881000 -     0x7fff90887ffb  com.apple.IOSurface (153.3 - 153.3) <3DD3BF22-0800-31F2-B179-87F87D6F0548> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff90888000 -     0x7fff908d8ff3  com.apple.ImageCaptureCore (7.0 - 7.0) <0F899C07-AA23-350E-8670-9090924D670D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x7fff908d9000 -     0x7fff90a35ff7  com.apple.ImageIO.framework (3.3.0 - 1582) <A9A63D25-DA38-33C0-98C6-F015952568B2> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff90a36000 -     0x7fff90a3afff  libGIF.dylib (1582) <B0435621-A64F-3E0E-AC03-35ED505A61B1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff90a3b000 -     0x7fff90b2cfff  libJP2.dylib (1582) <396280DF-6E69-38A5-883D-1EEBAC80771B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff90b2d000 -     0x7fff90b50fff  libJPEG.dylib (1582) <E2A44AAD-F6E0-3D74-80AE-BF2542AA6954> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff90b51000 -     0x7fff90b77fff  libPng.dylib (1582) <FB81BC9C-5BB7-373F-8464-C41A780F762A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff90b78000 -     0x7fff90b7aff3  libRadiance.dylib (1582) <825BE3AF-BB9D-3B84-8EFF-8F5FE4C837B8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff90b7b000 -     0x7fff90bd4fff  libTIFF.dylib (1582) <8C24B061-762D-3EC8-AC64-4961C030D575> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff90d00000 -     0x7fff917a3ff7  com.apple.JavaScriptCore (12602 - 12602.4.3) <671C706A-113C-3B69-8EEB-63F7DD64C08C> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fff917a4000 -     0x7fff917bdff7  com.apple.Kerberos (3.0 - 1) <49DCBE1A-130C-3FBF-AAEA-AF9A518913AC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff91a4a000 -     0x7fff91a50fff  com.apple.MediaAccessibility (1.0 - 97.1.1) <1025DB59-18DE-39EA-9C04-35CE8D6103E5> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff91a66000 -     0x7fff91fbafff  com.apple.MediaToolbox (1.0 - 1907.15.15) <937399ED-02B7-30EF-A0BA-7CD999DFE108> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff91fbb000 -     0x7fff92013fff  com.apple.Metal (86.18 - 86.18) <18670F91-B333-3A5D-A6AA-6F35FCD250C8> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff928e7000 -     0x7fff928effff  com.apple.NetFS (6.0 - 4.0) <6614F9B8-0861-338B-8FF0-8E402F96141C> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff92ac4000 -     0x7fff92accff7  libcldcpuengine.dylib (2.8.5) <CAEAABC2-E8B9-387A-ADBF-74F30AB43A91> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fff92acd000 -     0x7fff92bb3fff  unorm8_bgra.dylib (2.8.5) <1A39075B-6717-3FA5-A712-7F37583DB709> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
    0x7fff92c95000 -     0x7fff92ce3ff3  com.apple.opencl (2.8.6 - 2.8.6) <524989D1-5EB2-3E44-B575-BE67ACD60186> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff92ce4000 -     0x7fff92cfdffb  com.apple.CFOpenDirectory (10.12 - 194) <88E97774-6767-3A01-808B-C923F9310E20> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff92cfe000 -     0x7fff92d09ff7  com.apple.OpenDirectory (10.12 - 194) <0E4E32DD-6592-3860-9793-BAED6915AE0D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff92d0a000 -     0x7fff92d0cfff  libCVMSPluginSupport.dylib (13.0.10) <06D7F8EC-1D2B-38C2-B3FE-7D39185370BE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff92d0d000 -     0x7fff92d10ff7  libCoreFSCache.dylib (151.1) <40083774-8ADF-31E9-BEA1-092AB17B250F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff92d11000 -     0x7fff92d14fff  libCoreVMClient.dylib (151.1) <9CA7E2D4-F263-3610-9B56-9E7C05BEF138> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff92d15000 -     0x7fff92d1dffb  libGFXShared.dylib (13.0.10) <0257924D-0226-306C-817B-6B624AD8C80F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff92d1e000 -     0x7fff92d29fff  libGL.dylib (13.0.10) <9BDE83C8-D820-34AB-ADBB-89394EE706FB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff92d2a000 -     0x7fff92d66fe7  libGLImage.dylib (13.0.10) <38CB2689-C869-31A4-BECB-2E4F91F1FD1C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff92d67000 -     0x7fff92eddffb  libGLProgrammability.dylib (13.0.10) <96C3D0DF-73EB-3CEF-9527-03FA8C403546> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff92ede000 -     0x7fff92f1eff3  libGLU.dylib (13.0.10) <0303130B-3A1D-37C3-BEA5-0A2154C842D3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff93886000 -     0x7fff93894fff  com.apple.opengl (13.0.10 - 13.0.10) <7F1E35F8-F0D1-389B-B8CC-E06E02714005> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff93895000 -     0x7fff93a3bfff  GLEngine (13.0.10) <BCEDD508-5670-307C-ACC0-4B4740CE6D85> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fff93a3c000 -     0x7fff93a66ffb  GLRendererFloat (13.0.10) <91FFF901-0388-3FF0-B89B-9A0D2E992F13> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fff93aff000 -     0x7fff93c46fff  com.apple.QTKit (7.7.3 - 2978.3) <665AF577-900D-349E-B1C5-D5BDD70DB481> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x7fff93c47000 -     0x7fff93eb1ff7  com.apple.imageKit (3.0 - 1021) <5D77D4A4-F844-376B-93AA-F9CB55C719AE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x7fff93eb2000 -     0x7fff93f76fff  com.apple.PDFKit (1.0 - 1) <C1F429E3-1DCE-3F53-B189-19ED7F413D57> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x7fff93f77000 -     0x7fff9449dfff  com.apple.QuartzComposer (5.1 - 351.1) <A13FD5C2-36D1-3B92-88E6-AB4CAF733907> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x7fff9449e000 -     0x7fff944c1ffb  com.apple.quartzfilters (1.10.0 - 1.10.0) <8A8ED06E-3A07-312A-A976-982C51159A45> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x7fff944c2000 -     0x7fff945affff  com.apple.QuickLookUIFramework (5.0 - 720.5) <85A0BF0F-94B1-33CD-A3DC-4048380A3258> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x7fff945b0000 -     0x7fff945b0fff  com.apple.quartzframework (1.5 - 21) <DA6924FE-3D6C-3CCE-9CB6-188B6B1671DD> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x7fff945b1000 -     0x7fff947acff7  com.apple.QuartzCore (1.11 - 449.41.15) <32D80183-DCE4-34A7-AA46-DD1DE0DAA859> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff947ad000 -     0x7fff94802fff  com.apple.QuickLookFramework (5.0 - 720.5) <9E76504A-B17B-3302-82DF-9CE1CB31CAC3> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fff94803000 -     0x7fff94816ff7  com.apple.SafariServices.framework (12602 - 12602.4.3) <2DDAB5D4-6817-3CDC-B3D2-BCF6CED6E0FA> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
    0x7fff94d12000 -     0x7fff95031fff  com.apple.security (7.0 - 57740.31.2) <A47D7BAE-0591-3184-8E44-FB2EB08A19C2> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff95032000 -     0x7fff950a8ff7  com.apple.securityfoundation (6.0 - 55132.20.1) <9407620B-B230-3320-B0B7-5AE59F1D135C> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff950d2000 -     0x7fff950d5ff3  com.apple.xpc.ServiceManagement (1.0 - 1) <4E24C12E-6164-3A7A-8EB8-C2523492BAE8> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff9545c000 -     0x7fff954cdff7  com.apple.SystemConfiguration (1.14 - 1.14) <D9A57D90-E54F-3E1A-AA2F-F5A694BCE4BB> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff954ce000 -     0x7fff9587bfff  com.apple.VideoToolbox (1.0 - 1907.15.15) <DDD80F23-773E-38DC-A5E6-66CC4747758A> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff97b05000 -     0x7fff97b20ff3  com.apple.AppContainer (4.0 - 307.30.3) <EF4C3C83-6F51-38F7-A3D2-2D46EE4560EB> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fff97b21000 -     0x7fff97b2eff3  com.apple.AppSandbox (4.0 - 307.30.3) <D2C978EB-F4F1-3E79-9DB1-BEE2A92590CE> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
    0x7fff97b2f000 -     0x7fff97b51ffb  com.apple.framework.Apple80211 (12.0 - 1200.41) <360012DB-DAE7-3EEF-85F0-E5BE1DE3425D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff97b52000 -     0x7fff97b61fdb  com.apple.AppleFSCompression (88 - 1.0) <B6E2148F-BFBF-3F1B-A7DF-0F39190B4C20> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff97c52000 -     0x7fff97cdd97f  com.apple.AppleJPEG (1.0 - 1) <B4C3209B-58A5-359F-A898-F61B6C40E5E9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff97d16000 -     0x7fff97d19ff3  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6FF50E26-5BDA-3421-BDAE-B57AE6E4F6AC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fff97d1a000 -     0x7fff97d6cfff  com.apple.AppleVAFramework (5.0.34 - 5.0.34) <DADC6087-9B6D-3267-83BB-5DCF4A09B2E4> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff97d75000 -     0x7fff97d7cffb  com.apple.AssetCacheServices (31.2 - 31.2) <5E08DBDE-1DF0-37AC-9ED0-035A2ED67573> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
    0x7fff98102000 -     0x7fff98180fff  com.apple.backup.framework (1.8.3 - 1.8.3) <4B4950D4-8FD6-3503-9B08-C6553927725C> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff98e06000 -     0x7fff98e2dffb  com.apple.ChunkingLibrary (172 - 172) <83E91936-305D-32A4-A256-5582B96B1852> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff98e2e000 -     0x7fff98ec0ff7  com.apple.CloudDocs (1.0 - 485.12) <42A562A2-284D-3252-9341-855E52E45A02> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fff99756000 -     0x7fff9975fffb  com.apple.CommonAuth (4.0 - 2.0) <830B940B-3523-38DE-996D-695739616D10> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff998e3000 -     0x7fff99cc0fe7  com.apple.CoreAUC (224.0.0 - 224.0.0) <8DF6075A-0711-33A9-9031-6FDA22E85C4F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff99cc1000 -     0x7fff99cf1fff  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <5E1B0512-E50B-3534-99EF-AD15E601877A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fff99e7f000 -     0x7fff99e8ffff  com.apple.CoreEmoji (1.0 - 39.1) <0A46D6BF-22F3-39AD-B3DC-DE1EE5C442CC> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fff99f44000 -     0x7fff99f5aff3  com.apple.CoreMediaAuthoring (2.2 - 955) <3E1E33F1-B4FF-320E-B336-7E7F74D73642> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x7fff99f61000 -     0x7fff99ff1ffb  com.apple.CorePDF (4.0 - 4) <254118BE-2E30-3772-B425-6328D1487162> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x7fff9a172000 -     0x7fff9a1a2ff3  com.apple.CoreServicesInternal (276.2 - 276.2) <7D8DEF04-72F1-39F4-BBFB-09E65D7B8C10> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff9a432000 -     0x7fff9a4bcfff  com.apple.CoreSymbolication (61050) <F4B7C798-F7B7-3977-AA08-59A03F00308E> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff9a4bd000 -     0x7fff9a5fbfd7  com.apple.coreui (2.1 - 430.6) <42967F71-3DB1-3043-8647-B581DC095BD2> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff9a5fc000 -     0x7fff9a6acff3  com.apple.CoreUtils (5.0 - 500.9) <5567181B-721C-339E-A3DC-579E36D92341> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fff9a6fc000 -     0x7fff9a761ff3  com.apple.framework.CoreWiFi (12.0 - 1200.25.1) <BEFA276C-D284-3160-8641-7DD47E38C9D7> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff9a762000 -     0x7fff9a76fff7  com.apple.CrashReporterSupport (10.12 - 817) <CB5251B1-5BE5-308B-B30B-0050065E04CC> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff9a7e1000 -     0x7fff9a7ebff7  com.apple.framework.DFRFoundation (1.0 - 104.14) <258B6CFE-FD64-31C5-9973-2FD80597ECDA> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fff9a821000 -     0x7fff9a898ff7  com.apple.datadetectorscore (7.0 - 539.1) <E9892E38-3D5F-36CF-BDC5-E4E3C5516B55> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff9a8d5000 -     0x7fff9a914fff  com.apple.DebugSymbols (137 - 137) <B229F3F7-250B-3151-8048-CEA7BF80FA52> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff9a915000 -     0x7fff9aa26fff  com.apple.desktopservices (1.11.3 - 1.11.3) <CCE689AA-85F3-3587-AE12-1231E8ED127E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff9ab66000 -     0x7fff9ab70ff7  com.apple.DisplayServicesFW (3.1 - 380) <0A48A624-F5E7-3C29-8958-12219060F663> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x7fff9ad0a000 -     0x7fff9b13bff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <DEB42099-6927-332C-8D3E-D45096318D25> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff9c490000 -     0x7fff9c490fff  libmetal_timestamp.dylib (600.0.48.32) <34A09700-E06D-30BE-9580-0C54B9FB1498> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
    0x7fff9c49d000 -     0x7fff9c4a8ff3  libGPUSupportMercury.dylib (13.0.10) <99773A80-8B47-33F7-9406-96DC530FB586> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fff9c75c000 -     0x7fff9c778ff3  com.apple.GenerationalStorage (2.0 - 259.2) <00BF8427-967F-3693-A86F-DA0F29B49BF3> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff9c791000 -     0x7fff9ce30fff  com.apple.GeoServices (1.0 - 1228.22.8.29.13) <7A8294B0-2190-3764-B715-2AC7E2C7E231> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fff9ce76000 -     0x7fff9ceecfff  com.apple.Heimdal (4.0 - 2.0) <00F00E7E-7EF4-3254-86D3-ADA4F67938CF> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff9ceed000 -     0x7fff9cefefff  com.apple.HelpData (2.1.11 - 100) <86213EE9-C049-3084-8824-2A17A8DE2D6B> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x7fff9d50f000 -     0x7fff9d516ffb  com.apple.IOAccelerator (289.30 - 289.30) <C4F182BC-C1E3-306D-80FE-26D0F9E85342> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff9d518000 -     0x7fff9d52cff3  com.apple.IOPresentment (1.0 - 25) <40934217-996A-3DDB-A8C4-484CA0F0222B> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fff9d52d000 -     0x7fff9d54ffff  com.apple.IconServices (74.3 - 74.3) <3F0BD358-D019-3083-82F2-69CCAD5E5D66> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff9d5eb000 -     0x7fff9d5fbff3  com.apple.IntlPreferences (2.0 - 216) <589A5D92-6809-3F3C-900E-DBC60A07A101> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
    0x7fff9d632000 -     0x7fff9d7e8fff  com.apple.LanguageModeling (1.0 - 123.2.4) <FEB98F96-A9BB-3E6C-85B4-B466825B8C92> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff9d8c8000 -     0x7fff9d999ffb  com.apple.MMCS (1.3 - 381.1) <5582D879-5F26-3552-8E88-58703456EB7A> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
    0x7fff9de42000 -     0x7fff9de45fff  com.apple.Mangrove (1.0 - 1) <05039E9F-9C07-375B-A940-D90D455A2EC2> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fff9e0ac000 -     0x7fff9e125ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <6A759DBA-B7DF-363B-9827-AB1D1129BB34> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fff9e28b000 -     0x7fff9e296ff3  com.apple.MobileKeyBag (2.0 - 1.0) <8A7EEA75-8334-3FB5-A83B-F0ECB87952B2> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fff9e2a7000 -     0x7fff9e2cffff  com.apple.MultitouchSupport.framework (368.7 - 368.7) <A29E6031-E9A6-353A-BDE5-D8DF20FD393C> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff9e37e000 -     0x7fff9e388fff  com.apple.NetAuth (6.0 - 6.0) <1E7765FC-4580-3CE4-A0F1-CAA22006AE43> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff9ec04000 -     0x7fff9ec45ff7  com.apple.PerformanceAnalysis (1.145 - 145) <2D5D4A56-5F67-3BBB-9AAC-95FAC199877C> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff9f2bc000 -     0x7fff9f2e7ffb  com.apple.ProtectedCloudStorage (1.0 - 1) <4B38E6F6-AD64-3345-B51D-38E9DD518666> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff9f2e8000 -     0x7fff9f302fff  com.apple.ProtocolBuffer (1 - 249) <D8B7694B-B598-3728-8583-9C4CC0F05B64> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff9f303000 -     0x7fff9f313ffb  com.apple.QuickLookThumbnailing (1.0 - 1) <1A91596D-0A8D-3B7A-ACF5-783A78E9723E> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
    0x7fff9f31c000 -     0x7fff9f33fff3  com.apple.RemoteViewServices (2.0 - 124) <4765DC2E-CF05-38CF-9564-1FBACB7E167C> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff9ffab000 -     0x7fff9ffaefff  com.apple.SecCodeWrapper (4.0 - 307.30.3) <1B0B2122-C230-3E3F-8A81-EBD58818586B> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fffa003d000 -     0x7fffa00baff7  com.apple.Sharing (696.1.22 - 696.1.22) <D0A5C682-8996-3851-B332-AD05301E6FA3> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fffa00bb000 -     0x7fffa00daff7  com.apple.shortcut (2.16 - 98) <A7D38F28-73EB-3DF5-AE77-A95E4CB60DB9> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x7fffa00db000 -     0x7fffa0345ff3  com.apple.SkyLight (1.600.0 - 122.8) <ABE2AF30-53DA-3619-8638-ABA3F42DB6CC> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fffa0526000 -     0x7fffa0532ff7  com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <F9F0FCED-3A72-3639-91F2-B7EF248ED1B9> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fffa0c1b000 -     0x7fffa0c87ff3  com.apple.Symbolication (61080.2) <AAF840A6-2EFD-3DCB-8841-191A2FF39F6C> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fffa1081000 -     0x7fffa1087ff7  com.apple.TCC (1.0 - 1) <956F7C1A-D457-3FE0-9CFE-3F1719F0865C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fffa1116000 -     0x7fffa12deff7  com.apple.TextureIO (1.41 - 1.41) <3A9D9FD9-8997-3BD1-8046-76D0BF709806> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fffa1352000 -     0x7fffa1353fff  com.apple.TrustEvaluationAgent (2.0 - 28) <07C1F711-A1E0-3BAC-8F4D-977516D50925> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fffa1354000 -     0x7fffa14e4ff3  com.apple.UIFoundation (1.0 - 490.7) <047781ED-9E79-361F-8E04-71FF90C650F3> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fffa1f3f000 -     0x7fffa2002ff7  com.apple.ViewBridge (280 - 280) <6D4F6019-5ECC-377B-AF7D-9796E96841CB> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fffa242c000 -     0x7fffa2432fff  com.apple.XPCService (2.0 - 1) <BC3FCE26-6219-3316-949F-37F7005C9A0F> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
    0x7fffa2503000 -     0x7fffa2505ffb  com.apple.loginsupport (1.0 - 1) <4449ACBA-27A8-3311-BD92-CB7E63583FC6> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fffa255a000 -     0x7fffa2575ff7  libCRFSuite.dylib (34) <BACC371B-6153-36B5-BC54-3BCF26FBB221> /usr/lib/libCRFSuite.dylib
    0x7fffa2576000 -     0x7fffa2581fff  libChineseTokenizer.dylib (21) <09E74E18-ADB2-30D2-A858-13691CB1186C> /usr/lib/libChineseTokenizer.dylib
    0x7fffa2613000 -     0x7fffa2614ff3  libDiagnosticMessagesClient.dylib (102) <422911A4-E273-3E88-BFC4-DF6470E48242> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fffa2615000 -     0x7fffa2828fff  libFosl_dynamic.dylib (16.38) <A2F5E997-665E-35E1-8517-185364384863> /usr/lib/libFosl_dynamic.dylib
    0x7fffa2844000 -     0x7fffa284bfff  libMatch.1.dylib (27) <5D52A207-E2AF-3E05-8C51-91C1D82FCEE8> /usr/lib/libMatch.1.dylib
    0x7fffa284c000 -     0x7fffa284cfff  libOpenScriptingUtil.dylib (172) <D025E180-BB3B-3FFA-98FC-B6835354D723> /usr/lib/libOpenScriptingUtil.dylib
    0x7fffa284d000 -     0x7fffa2851ff3  libScreenReader.dylib (477.20.6) <8158E263-B7DF-3B0C-BABE-4FE94A53DFE5> /usr/lib/libScreenReader.dylib
    0x7fffa2852000 -     0x7fffa2853ff3  libSystem.B.dylib (1238) <6072D118-4AE8-33EC-89D9-204915BD0660> /usr/lib/libSystem.B.dylib
    0x7fffa28bf000 -     0x7fffa28eaffb  libarchive.2.dylib (41.41.1) <D53F0A5C-7FAA-3FCF-8A27-B7DF032C4221> /usr/lib/libarchive.2.dylib
    0x7fffa28eb000 -     0x7fffa29e0fef  libate.dylib (1.12.13) <DD046A96-07D9-3066-8BD6-D0E27FE9E1D3> /usr/lib/libate.dylib
    0x7fffa29e4000 -     0x7fffa29e4ff3  libauto.dylib (187) <5BBF6A00-CC76-389D-84E7-CA88EDADE683> /usr/lib/libauto.dylib
    0x7fffa29e5000 -     0x7fffa29f5ff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
    0x7fffa29f6000 -     0x7fffa2a04ff7  libbz2.1.0.dylib (38) <6FD3B63F-0F86-3A25-BD5B-E243F58792C9> /usr/lib/libbz2.1.0.dylib
    0x7fffa2a05000 -     0x7fffa2a5bff7  libc++.1.dylib (307.4) <BEE86868-F831-384C-919E-2B286ACFE87C> /usr/lib/libc++.1.dylib
    0x7fffa2a5c000 -     0x7fffa2a86fff  libc++abi.dylib (307.2) <1CEF8ABB-7E6D-3C2F-8E0A-E7884478DD23> /usr/lib/libc++abi.dylib
    0x7fffa2a87000 -     0x7fffa2a97ffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
    0x7fffa2a98000 -     0x7fffa2aadffb  libcompression.dylib (34) <AEF908E6-C0FE-3884-BD45-FB37A035545D> /usr/lib/libcompression.dylib
    0x7fffa2aae000 -     0x7fffa2aaeff7  libcoretls.dylib (121.31.1) <BCC32537-4831-3E9F-876E-8C9F4CF52FD3> /usr/lib/libcoretls.dylib
    0x7fffa2aaf000 -     0x7fffa2ab0ff3  libcoretls_cfhelpers.dylib (121.31.1) <6F37C5AD-7999-3D31-A52F-7AEED935F32D> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fffa2b6a000 -     0x7fffa2c4fff7  libcrypto.0.9.8.dylib (64.30.2) <D41E1901-06DD-3860-BB4F-B3ACE0284C01> /usr/lib/libcrypto.0.9.8.dylib
    0x7fffa2ded000 -     0x7fffa2e40ff7  libcups.2.dylib (450) <78243BA4-43AB-3364-8111-8D54D3382621> /usr/lib/libcups.2.dylib
    0x7fffa2e92000 -     0x7fffa2e99ff3  libdscsym.dylib (145.1) <E121E3BC-D2B7-37C3-86A8-5DFC3ECF94D6> /usr/lib/libdscsym.dylib
    0x7fffa2ebb000 -     0x7fffa2ebbfff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
    0x7fffa2ecb000 -     0x7fffa2ed0ff7  libheimdal-asn1.dylib (498.30.1) <4ED9F6E3-83BC-3302-B004-C25399DA0333> /usr/lib/libheimdal-asn1.dylib
    0x7fffa2ed1000 -     0x7fffa2fc3ff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
    0x7fffa2fc4000 -     0x7fffa31e9ffb  libicucore.A.dylib (57149.0.1) <6B5FDA93-AA88-318F-9608-C2A33D602EC7> /usr/lib/libicucore.A.dylib
    0x7fffa31ef000 -     0x7fffa31f0fff  liblangid.dylib (126) <3F4530C9-8BE1-3AA7-9A82-98694D240866> /usr/lib/liblangid.dylib
    0x7fffa31f1000 -     0x7fffa320affb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
    0x7fffa320b000 -     0x7fffa3221ff7  libmarisa.dylib (5) <2183D484-032D-3DE5-8984-3A14006E034E> /usr/lib/libmarisa.dylib
    0x7fffa3222000 -     0x7fffa34c9ff7  libmecabra.dylib (744.5) <EF046855-CB9C-32D8-B2F1-C85B526E386F> /usr/lib/libmecabra.dylib
    0x7fffa34fc000 -     0x7fffa3575ff7  libnetwork.dylib (856.30.16) <66C6E4D6-B39C-3309-80C1-CBBE170DDD51> /usr/lib/libnetwork.dylib
    0x7fffa3576000 -     0x7fffa394b127  libobjc.A.dylib (706) <47104A1B-13E8-369F-BC36-27FF465809FD> /usr/lib/libobjc.A.dylib
    0x7fffa394e000 -     0x7fffa3952fff  libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
    0x7fffa3953000 -     0x7fffa3983ff7  libpcap.A.dylib (67) <450DB888-2C0C-3085-A5F1-69324DFE902C> /usr/lib/libpcap.A.dylib
    0x7fffa39a1000 -     0x7fffa39bdffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
    0x7fffa39be000 -     0x7fffa39f7fff  libsandbox.1.dylib (592.31.1) <2AD6E696-E0FD-3D6E-98AD-050A08331597> /usr/lib/libsandbox.1.dylib
    0x7fffa3a0b000 -     0x7fffa3a0cff3  libspindump.dylib (230.3) <59FAC445-F8FB-3881-A69A-FD0E98100E19> /usr/lib/libspindump.dylib
    0x7fffa3a0d000 -     0x7fffa3b4efff  libsqlite3.dylib (253) <AECBC92F-FF00-3369-8ECB-AE053B3578B8> /usr/lib/libsqlite3.dylib
    0x7fffa3baa000 -     0x7fffa3bfafff  libstdc++.6.dylib (104.1) <91F66BFD-F927-301F-B8F3-578A5CEA78F4> /usr/lib/libstdc++.6.dylib
    0x7fffa3c43000 -     0x7fffa3c50fff  libxar.1.dylib (357) <58BFB84B-66FE-3299-AA3D-BBA178ADEE39> /usr/lib/libxar.1.dylib
    0x7fffa3c54000 -     0x7fffa3d43ffb  libxml2.2.dylib (30.11) <E12AF929-0FA5-3214-840F-C81E6AC9F36E> /usr/lib/libxml2.2.dylib
    0x7fffa3d44000 -     0x7fffa3d6dfff  libxslt.1.dylib (15.8) <FFF5DD45-F544-34B2-BE3C-DB877DC60081> /usr/lib/libxslt.1.dylib
    0x7fffa3d6e000 -     0x7fffa3d7fff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
    0x7fffa3d8e000 -     0x7fffa3d92ff7  libcache.dylib (79) <0C8092D3-600F-3ADD-A036-F225B6CDCA43> /usr/lib/system/libcache.dylib
    0x7fffa3d93000 -     0x7fffa3d9eff7  libcommonCrypto.dylib (60092.30.2) <B16E29B6-EC8D-3A8F-9A89-DD9CF35F7C4B> /usr/lib/system/libcommonCrypto.dylib
    0x7fffa3d9f000 -     0x7fffa3da6fff  libcompiler_rt.dylib (62) <E992E8D9-037C-3454-A366-A25E4D31D6BB> /usr/lib/system/libcompiler_rt.dylib
    0x7fffa3da7000 -     0x7fffa3daffff  libcopyfile.dylib (138) <64E285D9-5485-333B-AEE7-8B0C8FB9275F> /usr/lib/system/libcopyfile.dylib
    0x7fffa3db0000 -     0x7fffa3e33fdf  libcorecrypto.dylib (442.30.20) <2074B932-FD79-30A9-8E90-AF25C49F2AF1> /usr/lib/system/libcorecrypto.dylib
    0x7fffa3e34000 -     0x7fffa3e66fff  libdispatch.dylib (703.30.5) <EA0CC14E-D559-3802-B4B2-0E8C7579AAC4> /usr/lib/system/libdispatch.dylib
    0x7fffa3e67000 -     0x7fffa3e6cff3  libdyld.dylib (421.2) <6452FD53-DEBB-35EF-9DBC-7C587AB3BF40> /usr/lib/system/libdyld.dylib
    0x7fffa3e6d000 -     0x7fffa3e6dffb  libkeymgr.dylib (28) <1A318923-1200-3B06-B432-5007D82F195D> /usr/lib/system/libkeymgr.dylib
    0x7fffa3e6e000 -     0x7fffa3e7affb  libkxld.dylib (3789.41.2) <1ECFF219-6E4F-3B73-8350-814AA1B397EB> /usr/lib/system/libkxld.dylib
    0x7fffa3e7b000 -     0x7fffa3e7bfff  liblaunch.dylib (972.30.7) <15FACC21-079A-3BDF-9AFB-4253EFDEB587> /usr/lib/system/liblaunch.dylib
    0x7fffa3e7c000 -     0x7fffa3e81fff  libmacho.dylib (894) <A2F38EC1-C37C-3B93-B0E4-36B07C177F8C> /usr/lib/system/libmacho.dylib
    0x7fffa3e82000 -     0x7fffa3e84ff3  libquarantine.dylib (85) <C1D7749F-5F5F-3BB9-BEFC-1F0B9DA941FD> /usr/lib/system/libquarantine.dylib
    0x7fffa3e85000 -     0x7fffa3e86ffb  libremovefile.dylib (45) <CD42974E-BE0B-39FC-9BFC-8A7540A04DC6> /usr/lib/system/libremovefile.dylib
    0x7fffa3e87000 -     0x7fffa3e9fff7  libsystem_asl.dylib (349.30.2) <EFAC72D7-CB13-3DF7-ADF3-EC6635C6F1EA> /usr/lib/system/libsystem_asl.dylib
    0x7fffa3ea0000 -     0x7fffa3ea0ff7  libsystem_blocks.dylib (67) <B8C3701D-5A91-3D35-999D-2DC8D5393525> /usr/lib/system/libsystem_blocks.dylib
    0x7fffa3ea1000 -     0x7fffa3f2efef  libsystem_c.dylib (1158.30.7) <2F881962-03CB-3B9D-A782-D98C1BBA4E3D> /usr/lib/system/libsystem_c.dylib
    0x7fffa3f2f000 -     0x7fffa3f32ffb  libsystem_configuration.dylib (888.30.2) <4FE3983C-E4ED-3939-A578-03AD29C99788> /usr/lib/system/libsystem_configuration.dylib
    0x7fffa3f33000 -     0x7fffa3f36fff  libsystem_coreservices.dylib (41.4) <1A572B9E-0C47-320F-8C64-7990D0A5FB5A> /usr/lib/system/libsystem_coreservices.dylib
    0x7fffa3f37000 -     0x7fffa3f4fff3  libsystem_coretls.dylib (121.31.1) <4676F06D-274D-31BE-B61C-4D7A4AEF4858> /usr/lib/system/libsystem_coretls.dylib
    0x7fffa3f50000 -     0x7fffa3f56fff  libsystem_dnssd.dylib (765.30.11) <DC708D84-ED7D-3936-B996-A67C66B8DDAA> /usr/lib/system/libsystem_dnssd.dylib
    0x7fffa3f57000 -     0x7fffa3f80ff7  libsystem_info.dylib (503.30.1) <9ED9121C-F111-3FAD-BC2F-C95DEE1C9362> /usr/lib/system/libsystem_info.dylib
    0x7fffa3f81000 -     0x7fffa3fa3ff7  libsystem_kernel.dylib (3789.41.2) <C7CF3F92-81E9-3790-BC5F-A2732A8E782C> /usr/lib/system/libsystem_kernel.dylib
    0x7fffa3fa4000 -     0x7fffa3febfe7  libsystem_m.dylib (3121.4) <266DB92B-A86F-3691-80FB-1B26AD73CFF3> /usr/lib/system/libsystem_m.dylib
    0x7fffa3fec000 -     0x7fffa400aff7  libsystem_malloc.dylib (116.30.3) <F40DEE3B-386A-3529-A3F7-98117ED55BF4> /usr/lib/system/libsystem_malloc.dylib
    0x7fffa400b000 -     0x7fffa4062ffb  libsystem_network.dylib (856.30.16) <4AE368E9-605D-379D-B04C-2AC7455B8250> /usr/lib/system/libsystem_network.dylib
    0x7fffa4063000 -     0x7fffa406cff3  libsystem_networkextension.dylib (563.30.15) <EB020B0C-7DF0-3EEF-8E3C-15DA3C01D687> /usr/lib/system/libsystem_networkextension.dylib
    0x7fffa406d000 -     0x7fffa4076ff3  libsystem_notify.dylib (165.20.1) <E7FD3A7C-DD07-36E2-9FA4-7561F9F114DA> /usr/lib/system/libsystem_notify.dylib
    0x7fffa4077000 -     0x7fffa407ffe7  libsystem_platform.dylib (126.1.2) <3CA06D4E-C00A-36DE-AA65-3A390097D1F6> /usr/lib/system/libsystem_platform.dylib
    0x7fffa4080000 -     0x7fffa408aff7  libsystem_pthread.dylib (218.30.1) <C869ED7C-BE29-3532-8E69-3A8DA1447EDC> /usr/lib/system/libsystem_pthread.dylib
    0x7fffa408b000 -     0x7fffa408eff7  libsystem_sandbox.dylib (592.31.1) <7BBFDF96-293F-3DD9-B3A4-7C168280B441> /usr/lib/system/libsystem_sandbox.dylib
    0x7fffa408f000 -     0x7fffa4090fff  libsystem_secinit.dylib (24) <5C1F1E47-0F7D-3E25-8DEB-D9DB1F902281> /usr/lib/system/libsystem_secinit.dylib
    0x7fffa4091000 -     0x7fffa4098fff  libsystem_symptoms.dylib (532.30.6) <145C2AD9-4DAD-3F58-AD22-60DFFD8F13FF> /usr/lib/system/libsystem_symptoms.dylib
    0x7fffa4099000 -     0x7fffa40b9ff7  libsystem_trace.dylib (518.30.7) <365E2928-396A-3587-AA16-27A88DBAFB3E> /usr/lib/system/libsystem_trace.dylib
    0x7fffa40ba000 -     0x7fffa40bfffb  libunwind.dylib (35.3) <9F7C2AD8-A9A7-3DE4-828D-B0F0F166AAA0> /usr/lib/system/libunwind.dylib
    0x7fffa40c0000 -     0x7fffa40e9ff7  libxpc.dylib (972.30.7) <65E41BB6-EBD5-3D93-B0BE-B190CEE4DD93> /usr/lib/system/libxpc.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 1
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 17742
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=365.1M resident=0K(0%) swapped_out_or_unallocated=365.1M(100%)
Writable regions: Total=338.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=338.5M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               384K        4
Activity Tracing                   256K        2
CG backing stores                 12.7M        9
CG image                           436K       52
CoreAnimation                      160K       19
CoreUI image data                 3440K       31
CoreUI image file                  180K        5
Foundation                          28K        3
Image IO                            36K        6
Kernel Alloc Once                    8K        2
MALLOC                           288.1M       77
MALLOC guard page                   64K       13
Memory Tag 242                      12K        2
OpenCL                              32K        5
SQLite page cache                   64K        2
STACK GUARD                       56.1M       19
Stack                             16.6M       20
VM_ALLOCATE                        244K       44
VM_ALLOCATE (reserved)             256K        2         reserved VM address space (unallocated)
__DATA                            41.1M      306
__GLSLBUILTINS                    2588K        2
__IMAGE                            528K        2
__LINKEDIT                       118.8M       43
__TEXT                           246.3M      313
__UNICODE                          556K        2
mapped file                       73.2M       51
shared memory                     16.4M       18
TOTAL                            878.3M     1027
TOTAL, minus reserved VM space   878.1M     1027
Model: MacBookPro10,1, BootROM MBP101.00EE.B0B, 4 processors, Intel Core i7, 2,7 GHz, 16 GB, SMC 2.3f36
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1024 MB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xEF), Broadcom BCM43xx 1.0 (7.21.171.68.1a5)
Bluetooth: Version 5.0.3f1, 3 services, 27 devices, 1 incoming serial ports
Network Service: Thunderbolt Ethernet, Ethernet, en4
PCI Card: Apple 57762-A0, Ethernet Controller, Thunderbolt@195,0,0
Serial ATA Device: APPLE SSD SM256E, 251 GB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 3.0 Bus
Thunderbolt Bus: MacBook Pro, Apple Inc., 23.4
Thunderbolt Device: Thunderbolt to Gigabit Ethernet Adapter, Apple Inc., 1, 5.5
Thanks a lot
I am also seeing crashes.  I imported 90 items via CSV.
I have a lot of records with blank fields (import functionality really needs improvement).
Now when I try to delete a field on iOS the app crashes consistently.  On macos, the app crashes sometimes, and sometimes affects the wrong field (sounds like same symptoms as original poster).
Hi Guys,
I am so sorry that you were welcomed by this creepy bug:/. But the good news is that we have found this issue with Generic CSV/DSV import, and we will fix it in next Beta release (due soon). You can turn on the beta updates in Desktop version from Enpass settings.
  • Log into Enpass --> Preferences --> Advanced --> Enable Beta updates.
Till then I request you to please bear with us.
cheers!
Thanks @Anshu kumar
I hope you can fix this soon.
I had the Mac App Store version, which does not have the ability to enable beta updates. I've downloaded the latest version from website, and now I've successfully enabled beta updates.
  • 3 weeks later...
Any news on fixing this?  I cannot edit anything that has been imported  -- the app crashes everytime I try.
Hi @mike carlton,
I can understand the level of frustration at your end. This issue has been fixed and it is in Testing phase. Hopefully, it will be available before the end of this month. Till then I request you to please bear with us.
  • 4 weeks later...
Looks that the problem has been solved for me with Enpass 5.5.0 (79)
Thanks a lot
Edited by Eduard Bosch
