Error 1104001 while trying to sync to iCloud
Hello,
I'm trying to sync my Enpass to my icloud (as always) but I keep getting the following error: 1104001. Is there anyone here that can help me figure out what is going on?
Thanks in advance!
Hey @DianaofThemiscyra,
Sorry for the trouble you're going through.
For quick troubleshooting please try re-connecting the iCloud sync from Enpass settings and let me know if the problem persists.
Thanks!
  • 4 weeks later...
My icloud sync is impossible.
I don't know how to do.
On 10/22/2019 at 4:54 PM, Gaël said:
Have you tried to do what @Anshu kumar  said on a previous post in this thread?
  • 2 weeks later...
Yes of course.
I installed Enpass on my windows 10 and i would like to install and synchronize Enpass on my macbook and my iphone, but sync is impossible with icloud.
Error message of impossible sync.
And i payed 10 euros the app in app store.
So, what is your solution ?
thanks
Sorry Gaël,  I don’t have an answer for you. I did what Anshu Kumar said and for me it worked. Also I don’t use Windows system, all my devices are  MacOS / IOS based. But I do have a suggestion that I hope can help you somehow. Connecting to iCloud dot com  with a web browser and going to iCloud Drive page you should see the Enpass directory, do you have a walletx file inside? I have two. The OLD and the new one. Have you tried to download it to your computer and maybe adding the data from there to then create a new password database (without losing what you already have) . I’m not sure this works, I never did it, since for me what worked the was the suggestion from Anshu Kumar. But maybe it could help you. Another suggestion would be ask directly to Apple since this might be an authorization problem and probably they could help you a bit more from their end.
I hope this can help you somehow, sorry if I can’t be of more help.
Thank you very much for your prompt response and suggestions.
I retried the synchronization by repeating the same manipulations and it worked this time.
I do not see a WalletX file and I have no explanation but the goal is reached.
Thanks again.
