Move Enpass Vault/DB to iOS
I purchased the Mac/OSX version of Enpass and created a Vault with 200+ entries.
My goal now is to move the Vault to an iPad running iPadOS. I plan to NEVER update the Enpass from iPad. Only update it on the Mac. But I do NOT want to leave a copy on ANY Cloud.
1) Is there any way to copy the Vault from Mac to a USB drive and then import the Vault into EnPass on a iPad Pro running iPadOS?
2) If answer to 1 is NO, Assume I backup the Vault from Mac to Dropbox and then I sync the Vault from Dropbox to iPad. AFter the sync is complete, what happens if I delete the Vault from Dropbox? Will the iPad continue to work correctly?
Thank you
Hey @Dilip,
Thanks for using Enpass.
To restore Mac data on iPad, you can use supported clouds. To sync data between Mac and iPad, use any cloud account to setup sync on both devices and later disconnect the sync and delete the backup file on cloud provider.
Hope this helps! Please confirm if you face any issue.
Thanks!
