October 1, 20197 yr HiI bought Enpass Paswordmanager through Apple's Appstore. Version 6.2.0Unfortunately, the Touch ID function only works occasionally. Although in the settings TouchID is activated
October 4, 20197 yr Hello @Dirk Nolden, Thanks for using Enpass. There is an intermittent issue with Touch ID in iOS 13. Could you please confirm the device you're using? Thanks!
October 28, 20197 yr On an iOS device, there's a capacitive ring around the Touch ID sensor; on the new MacBook Pro, the entire Touch ID sensor is capacitive. When the sensor detects a finger, it triggers a high-resolution image capture. That image is converted into a mathematical representation myloweslife.com, which is then sent through the hardware channel to a secure enclave. If the representation matches what's stored in the enclave, a "yes" token is released and the Touch ID action is authenticated. If not, a "no" token is released, all you get is a digital head shake. Every time Touch ID scans a finger and recognizes it, it adds additional detail to the representation, theoretically to make it register even faster and better in the future. Edited October 29, 20197 yr by jelreinew to make it better.
