Editing an entry > Not responding
Hi there,
I am using Enpass Desptop for Windows in v5.5.3 on Windows 7 and Windows 10.
On both systems, the application hangs for about 10 seconds if editing an entry. The whole application window goes white and the title bar says "Enpass (not responding)". I have to wait about 10sec, then it's working. This happens ALWAYS when editing.
Also the application in general isn't the fastest. My database isn't so big (~220 entries).
Best regards
Julian
Hi @7Bit,
Sorry to hear about your trouble. Please share some more info so that we can investigate where the problem could be?
  • Which cloud sync are you using?
  • Have you changed the default location of Enpass database on your PC?
Thanks for your co-operation!
