Enpass Often Freezes
I've been using enpass for quite some time now as my main password manager however as of recently I appear to be having the occasion issue with searching.
Every so often I will try to search for a password and enpass will suddenly freeze (at times for more than 60 seconds).
I am currently running the latest version of enpass and have a pretty fast computer with SSD drives and plenty of ram. I have a little over 600 items in my enpass manager.
I've also noticed that this started happening since the release of enpass with attachment support. I do not store any attachments on my enpass.
Is this a known issue and or is there anything that can be done to help prevent this from happening?
Hi @Nicarlo
Thanks for reporting this issue and I apologize for the inconvenience. I have noted down this issue and forwarded to the testing team. Meanwhile, please enable title only in the search field and let me know if the problem still persists.
Thanks for your co-operation!
Hey Anshu!
Thank you for the quick reply. I have updated the search option and selected Title Only however I appear to be be having the same issue.
Let me know if there's anything else that you could think of that could be causing this.
Thank you!
Hi @Nicarlo
That's really strange. To get a more clear picture about the issue, we may requires some further details. So please contact our support team at support@enpass.io with a reference to this forum post.
