December 17, 20196 yr Hello, I have an Error on all devices at nextcloud sync with webdav: I have delete the sync and all data on nextcloud and setup the sync new, but nothing helps. Pls Help... Thanks Spawnsen Edited December 17, 20196 yr by Spawnsen
January 3, 20206 yr Hi @BeZazz, For quick troubleshooting disconnects the sync from all the devices and reconnect it. If the issue persists, please share the demo account of your WebDAV via email at support@enpass.io so that we can investigate where the problem could be. Thanks for your cooperation.
May 22, 20206 yr i have the same error code since. No solution yet. Deleting data on ownCloud doesn't solve the problem. Changing the account on ownCloud doesn't solve the problem. So enpass is now completely worthless and i have to switch everything to keepass :-(
May 22, 20206 yr Hey @T9896813518 Welcome to the forum! Sorry for the inconvenience caused to you. For quick troubleshooting disconnects the sync from all the devices and reconnect it again. If the issue persists, please share the demo account of your WebDAV via email at support@enpass.io so that we can investigate where the problem could be. Thanks for your co-operation.
