February 26, 20206 yr Backup Frequency I want to schedule daily/weekly/monthly backups. Or tell us when "auto backup" decides to backup. Backup Limit/Retention Policy I want to limit/retain the auto-backups either by time or number. For example: A) Only keep X number of backups. B) Do not keep backups older than X months. C) Fancier policy: Daily Backup + Weekly Backup + Monthly Backup + Quarterly Backup + Annual Backup. Thank you.
February 28, 20206 yr Hi @jakejohn, Thanks for contacting to us. Currently, in Enpass, there is no option to select a backup schedule as it gets triggered when you make some changes in the database. The auto-backup folder contains only 60 latest back-ups. You can also manually choose the backup of a specific vault, or of whole Enpass data from File under ≡ menu from Toolbar → Backup, All Vaults → Select file location → Save.
May 2, 20205 yr Backing up the vault when a change is made is fine but 60 retained versions is a bit high for me. I think the ability to set a limit on the number of backup files would be a great option. Also, deleting backups older than some number of months would be very good.
May 4, 20205 yr Hey @rlengland Thanks for writing us. I have noted your request and notified the same to the concerned team. Thanks for the suggestion.
