March 2, 20206 yr Hi @NetWeb Welcome to the forum! What Enpass version are you using? If you haven't tried the latest version 6.4, which is presently in Beta, please install Enpass Beta and check if the same issue persists.
March 5, 20206 yr Hi @NetWeb Sorry to hear that. Could you please share your device detail along with OS version, so that we can help you better. Thanks.
May 22, 20206 yr Author Its an iPohone XR iOS 13.5 ... still the same bug there. i got the newest app version.
May 22, 20206 yr Hey @NetWeb Apologies for the inconvenience. Please share the scenario in which items got duplicated before performing Auto-fill or it is always showing duplicate entry on your device? Thanks.
May 27, 20206 yr Hi @NetWeb, We need a little input from you, please follow the steps mentioned below and revert to us: 1. Go to device settings > Passwords & accounts > Autofill Passwords 2. Disable Autofill passwords option > enableAutofill passwords option > click on Enpass > Click on Done button 3. Now, Open Enpass app > stay there for few seconds/create update any item 4. Now, check the quick tab bar If it shows duplicate items.
