March 16, 20206 yr Hi, Starting from version 6.4.0, when I unlock Enpass using a PIN, I have to click on the "Unlock" button with the mouse, because the ENTER key does nothing. Of course this is just a little annoyance, not a critical bug, but can it be fixed in the next release? Thanks.
March 18, 20206 yr Hi @lammoth, Sorry for the inconvenience caused to you. Please revert to us with the answer to the following queries and we will get it sorted out for you: On which device (along with OS version) are you using Enpass? Which Enpass and Enpass extension version are you using?
March 18, 20206 yr Hi @Pratyush Sharma Environment info: Device: Acer Chromebook (CB714 with Pentium 4417U) OS Version: 80.0.3987.137 (Official Build) (64-bit) Enapss: 6.4.1.329 Extension: 6.4.0 The scenario is: PIN is correct Pressing ENTER key does nothing Clicking with the mouse on "UNLOCK" works Edited March 18, 20206 yr by lammoth
March 19, 20206 yr Hi @lammoth, Thanks for sharing the details. I have noted down this issue and notified the QA team to look into it. Till then, we will request you to please co-operate with us.
March 20, 20206 yr Hi @lammoth, Update We found this issue and our Dev team is looking into it. Hopefully, fix will be available in the subsequent update(s). Thanks.
August 8, 20206 yr Hi @Pratyush Sharma This issue is back in the latest version of Enpass -> 6.5.0.390
August 10, 20206 yr Hey @lammoth Thanks for notifying us. I have shared your feedback with the concerned team to fix this issue. Hopefully, the same will be resolved in the future version of Enpass. Please co-operate with us. Thanks!
