April 1, 20206 yr I did some work on structuring my list/logins, so I copied many passwords briefly and pasted them into additional entries. I did not delete the old entries but changed them because I had put together a few logins, which I now wanted to have listed separately. Now under the category "Identical passwords" they are now listed although I deleted the passwords after I copied them. Can I update the list of the password check or are the passwords somehow cached even though I deleted them?
April 21, 20206 yr The deleted passwords would be in the "Trash" folder in Enpass. Make sure you empty the "Trash" only after you've saved the passwords somewhere else.
