April 17, 20206 yr I have installed Enpass locally and I've been using it for months now and I couldn't be happier. I have payed the one-time fee at $39.99. Now I want my family to use it but when I open the app on their phones it says I have to enter a subscription. What gives?
April 20, 20206 yr Hey @mattias Thanks for using Enpass and writing to us. Enpass is an In-App purchase, for which the Family sharing is technically not feasible. To know more, read Apple App Stores’ guidelines and the Google Play Stores’ T&C using this link. However, you can use the same email account(with which you have purchased the Enpass app) to use Enpass all features on their devices. Please have a look at this FAQ to restore purchase on other devices. In case of any query, please share your purchase receipt at support@enpass.io so we can help you better. Thanks.
April 24, 20206 yr Author @Garima Singh I want to make so that my family members have their own Vault and we have one vault that is shared between us - is this possible with the current Apple app store guidelines?
April 24, 20206 yr Hey @mattias Thanks for writing back. Yes, absolutely. You can ask your family to register the Enpass using the same email account with which you have purchased Enpass and then create their own vault and also you can share a vault with everyone. To do so, please refer to this FAQ. Hope this answers your question.
August 3, 20215 yr This is the page that turns up on top when you google for 'enpass family sharing', but it doesn't really clearly explain how to share a vault with a family member. Nor does the FAQ. I'm not sure about all clouds, but if you are iCloud or Google Drive user, you'll want to save your main vault to your iCloud or Google Drive account or whatever you use to keep your personal devices in sync. But you can't seem to share your personal iCloud / whatever account with a family member, because iCloud accounts are unique and can only be accessed by one user. So the only way to share a vault, is to set up a dedicated cloud account, specially for 'family vault sharing'. It is mentioned in the FAQ as a 'suggestion'. This sounds as if it's optional, but it's not. It's the only way to sync between different users. edit: Since I already use Dropbox and iCloud, don't want to set up a WebDAV-server for, Box' website prices page didn't work and I don't trust Google with my password db, even if it's encrypted, I choose Nextcloud. There are free Nextcloud accounts available everywhere Once you know how it works / doesn't work, you can set it up relatively easily, but it took me hours to figure it all out. There is no guide on the enpass site. Enpass has YouTube videos, but not about the one I needed most: Setting up a family / shared vault. My suggestion therefore is: Make a video how to set up / share a vault with family. And not just the 'create vault / set password' 1-minute click-through, but also why / how to choose the extra cloud service you'll need for it and set up the account. It would make Enpass easier to use and imho would save the Enpass team from a lot of support questions For anyone with the same question: Basically, the steps are: Get a family account Install the Enpass apps on your devices and from within the desktop app the plugin(s) for your browser(s) Create your main vault / set password Sync them via a cloud service. Use the cloud you already use for other synching. FIRST add family / team members in https://console.enpass.io/ Do the same for them: Install Enpass apps / plugins on their devices, set up the main vault, sync it. Set up a new, separate cloud account that you're going to use for the shared vault. Since you can't have two iCloud accounts.. (well technically you can, but it's not worth the trouble imho) it's best to set up an account on a service you don't use already. That way it's easier to keep them apart. Or create another Dropbox, Box, whatever account for this. Create a new vault, on your device, name it, for example 'Family'. Sync it via the new, separate cloud account. You'd think you can add this vault to the Enpass app of others, but this is less obvious as you'd think. You need to set up a new vault on each members' device, name it manually(! So be sure to name it correctly, there is no automatic 'check'). Don't forget to sync it with the new, separate cloud account. Test it by adding an entry from one app, sync manually or restart the app and check if it syncs both ways. Edited August 3, 20215 yr by laptopleon added info to explain how to do it yourself
