April 18, 20206 yr Importing a Pre-formatted CSV as "Other Miscellaneous" Adds empty Fields "Field 1" and "Field 2" to ALL imported items. I am guessing this is because the built-in template for "Other Miscellaneous" has "Field 1" and "Field 2" as generic Fields to "get you started"??? I believe removing these Fields from the "Other Miscellaneous" Template would resolve this issue. Using: Enpass 6.4.2 (632) On a side note: it would be nice to be able to select a Custom Template for importing items. Edited April 20, 20206 yr by bu11etpr00f
April 20, 20206 yr Hi @bu11etpr00f Thanks for using Enpass and writing to us. Currently, the option to create a custom template is only available in Desktop version of Enpass, you can read this link to create a template in Desktop. Also, I really appreciate you for exploring the app and giving time in finding this valuable suggestion. Thanks.
April 20, 20206 yr Author @Garima Singh I am reporting a bug. Please do not mark this thread as being "answered" simply because you referenced my added feature request to import using a custom template... Please re-read my post. I AM using the Desktop version of Enpass...the only version allowing you to "import from a Pre-formatted CSV". Again, the issue / bug is: When importing a Pre-formatted CSV as "Other Miscellaneous" Enpass Desktop ADDS empty Fields "Field 1" and "Field 2" to ALL imported items.
April 21, 20206 yr Hey @bu11etpr00f Thanks for writing back. Please share the device detail along with OS version on which you have imported the data? Also the Enpass version so that we can investigate the issue better. Thanks.
April 22, 20206 yr Hey @bu11etpr00f Please check if there are any two heading fields named as "Field1 and Field 2" in the imported file. Also recheck the file to ensure that there is no any Heading column without any data in it. If present(empty field), please remove those fields and import the same file. (Just like the attached screenshot, there is field name "Field 5" which is empty). Thanks.
April 27, 20206 yr Author @Garima Singh I listed the Enpass version I am using in my original post (6.4.2 (632)). I am using macOS 10.15. No, there is not "any two heading fields named as "Field1 and Field 2" in the imported file". I have attached a screenshot of sample header for items I have imported. Please test this and duplicate this for yourself. Use any template you like, and import it as "Other Miscellaneous". It'll import your data correctly, and afterwards, if you go to edit an imported item, you will see the empty Fields "Field 1" and "Field 2". I have done this several times with the same results. For obvious reasons, my screenshot does not have any actual data below each column. Edited April 27, 20206 yr by bu11etpr00f
April 28, 20206 yr Hi @bu11etpr00f, Thanks for sharing the details. I have shared the inputs to the concerned team to look into the issue. Thanks for the co-operation.
