May 9, 20206 yr Enpass 6 Autolock When System is locked does not work. I tried several times but without luck, rebooted PC and same. Operating System: Windows 7 64-bit Enpass: 6.4.1 (643) (Traditional Win32) Firefox extension: 6.4.0
May 11, 20206 yr Hi @Maxsi, Sorry for the inconvenience caused to you. Please share the screenshot of the Enpass security setting so we can further investigate this issue.
May 11, 20206 yr Author 2 hours ago, Pratyush Sharma said: Hi @Maxsi, Sorry for the inconvenience caused to you. Please share the screenshot of the Enpass security setting so we can further investigate this issue. Here is the screenshot of the security setting
May 12, 20206 yr Hi @Maxsi, Thanks for sharing the details. I have noted down this issue and notified the QA team to look into it.
May 14, 20206 yr Hi @Maxsi, We need a little input from your side, can you please let us know are you facing this problem when you manually lock the system using (cmd+L) button or when the system gets auto-locked. Also, please let us know are you using any Antivirus or third party security app which keeps the active background process. Thanks for your co-operation.
May 14, 20206 yr Author 1 hour ago, Pratyush Sharma said: Hi @Maxsi, We need a little input from your side, can you please let us know are you facing this problem when you manually lock the system using (cmd+L) button or when the system gets auto-locked. Also, please let us know are you using any Antivirus or third party security app which keeps the active background process. Thanks for your co-operation. When system is manually locked. I have it installed in two laptops, one with antivirus and the other one without. Edited May 14, 20206 yr by Maxsi
May 14, 20206 yr Hi @Maxsi, Thanks for sharing the details. I have noted down your input and notified the QA team to look into it.
May 15, 20206 yr Author On 5/14/2020 at 3:46 PM, Pratyush Sharma said: Hi @Maxsi, Thanks for sharing the details. I have noted down your input and notified the QA team to look into it. I hope that there will be an update soon to fix this.
May 18, 20206 yr Hey I would like to inform you that our team is not able to reproduce the issue till now as it is working fine on our systems. However, they are trying best to reproduce the same. Thanks.
May 20, 20206 yr Hey @Maxsi Thanks for the patience. We've released an updated version of Enpass. Could you update the app to the latest version and let us know if you're still encountering the same issue with the app? If the problem persists, please share the following things: Is the issue occurring on both of the laptops? (If yes, their versions) Which antivirus you using? (with version) Are you working on Admin account or User account? Thanks for the co-operation.
May 24, 20206 yr Author On 5/20/2020 at 4:54 PM, Garima Singh said: Hey @Maxsi Thanks for the patience. We've released an updated version of Enpass. Could you update the app to the latest version and let us know if you're still encountering the same issue with the app? If the problem persists, please share the following things: Is the issue occurring on both of the laptops? (If yes, their versions) Which antivirus you using? (with version) Are you working on Admin account or User account? Thanks for the co-operation. Thanks for the update. I have updated Enpass on both laptops but unfortunately the issue is not resolved. Following is the information you asked for; 1) Yes the issue occurs on both laptops. What do you mean by their version? Both are running windows 7, 64-bit system, i5. Brands are HP & Toshiba. 2) Antivirus is Trend Micro OfficeScan 12.0.5383 which is installed only in HP laptop. Toshiba laptop does not have antivirus. 3) Admin user in Toshiba. In HP guest user but I had login as admin and still the same.
May 25, 20206 yr Hi @Maxsi, Thanks for sharing the details. I have noted down your input and notified the QA team to look into it.
