May 14, 20206 yr Hi, I cannot make the Portable app working on Mac. How can I get the data from Enpass Desktop 6.4 to Portable app ? I am looking for a "walletx.db" file, as said in the user guide, but where is it ? When the USB key is plugged on my own laptop, will Desktop and Portable datas sync together, and how ? Thanks.
May 15, 20206 yr Hi @DELABRIERE, Sorry for the inconvenience caused to you. Enpass version 6 doesn't have the file extension walletx.db instead it is vault.enpassdb. File name walletx.db was for the older version of Enpass. To restore data in Portable from your Desktop, you can manually take the backup of whole Enpass data from File under ≡ menu from Toolbar → Backup All Vaults → Select file location → Save. Now restore the saved backup file in Portable and let us know if the issue persists. If you choose to save the database in USB, then you can access the data through the same USB on any device.
May 15, 20206 yr Author Hi, Thank you for your answer. When I try to restore data from the saved backup, I get this message: "Internal error: -995" What should I do ? Thanks again.
May 18, 20206 yr Hey @DELABRIERE Please follow move EnpassPortable.app to different location or USB then try the same steps and let me know. If the problem persists, please share- What is the size of your back up file? Also, the file format of backup file? Have you taken complete back up of Enpass data from desktop and then tried to restore the same on the portable or usb? If yes, please share the screenshot of the error you getting while restoring the backup? On 5/14/2020 at 7:49 PM, DELABRIERE said: I am looking for a "walletx.db" file, as said in the user guide, but where is it ? In which user guide you see about "walletx.db" ? Thanks.
May 18, 20206 yr Author Hi, - The size of the backup 21 Mo. Is there a limit to use a backup on the Portable app ? - Yes, that's what I did. Copy of the error screen. - "walletx.db" is mentioned in the Enpass Portable user guide. See copy of the screen.
May 18, 20206 yr Author And: Pratyush Sharma said: "Enpass version 6 doesn't have the file extension walletx.db instead it is vault.enpassdb". How can I get such a file ? My backup name is "2020-05-18-1589793508-4_vaults-165_items.enpassbackup" Thanks
May 18, 20206 yr Hi, The auto-backup and the backup files have a different extension. The extension vault.enpassdb is for the vault database. Thanks.
May 19, 20206 yr He @DELABRIERE Thanks for sharing the details. It seems that you are using old version of portable. Please take a backup of Enpass data in the same portable version(if you have any). Afterwards, delete the existing Enpass portable installation from your system. Once you remove the Enpass portable installation, download Enpass portable again using this link and restore the data which you backed up earlier. Also, change the directory location for Enpass portable. Thanks.
May 19, 20206 yr Author Hi, I am using the last version of Enpass Portable 6.4 (the user guide has not been updated to this version). What kind of backup should I use ? Backup of the vaults ? Any other ? Thanks
May 20, 20206 yr Hey @DELABRIERE Sorry for the trouble you are going through. Please use the backup file you have made manually(in .enpassbackup file format) to restore the same on the USB and share the findings with us. Thanks.
May 20, 20206 yr Author Hi, Sorry, but I did, again, what you advised to me, I still get this message: "Internal error -995"...
May 21, 20206 yr Happening the ame to me too 1. I downloaded the latest enpass portable file 2. When trying to load the backup file ending with *.enpassbackupdb generated by auto saving of vault by the desktop app, it get the internal error -995 Please help
May 21, 20206 yr Hey @John Doe and @DELABRIERE Thanks for reporting this issue. I have noted down this issue and notified the QA team to look into it. Thanks for your co-operation.
May 21, 20206 yr Thanks. Any idea when the fix would be available. I have waited for the portable app to work for a long time i am using iCloud for syncing.
May 22, 20206 yr Hey @John Doe and @DELABRIERE Our QA is looking into this issue. Meanwhile if you are using Enpass on any other devices and syncing with any cloud services then enable sync or restore with the same cloud account on the portable version of Enpass. Also, please let me know on which device along with OS version you are using Enpass? Thanks for your co-operation.
May 22, 20206 yr Author Hi, I am using Enpass and Enpass Portable on a MacBook Air, OS 10.14.6. Unfortunately, I cannot sync the Portable version with the cloud, because I am using iCloud, which is not available... Thanks
May 22, 20206 yr Hey @DELABRIERE Thanks for writing back. Sorry to say but adding the iCloud sync support for the Portable version of Enpass is quite a cumbersome process, however, it's already in our roadmap for the future version. I have already created feature request for the same. But I am afraid to say that you have to choose any other cloud services to sync Enpass data on your macOS device and then restore the database on the portable version of Enpass. Thanks for your co-operation.
May 23, 20206 yr Hi - on the back of your advice, I changed my sync from iCloud to google Now when I go to enpass portable, and give it authorization to sync via google - i get the below screen (attached). I click on copy, and immediately after that EnPass portable which is open - shuts down on my Mac What am I doing wrong?
May 27, 20206 yr Hi @John Doe, Thanks for sharing the detail. Please try after changing the default browser. If you still face the issue with another browser, let us know.
May 27, 20206 yr Author Hi, Do you mean my internet browser (Safari) ? I don't use it, or any other, during install of your app...
May 28, 20206 yr Hi @DELABRIERE, Thanks for writing in. Please try to use Chrome as a default browser and let us know If the issue persists.
