Link Items
Often an item is related in some way to another item.  It would be helpful to be able to embed a link from one to the other to make jumping between them easy. The way I see this working would be to create a field type called Link. Then that field would provide a button to pick the item to link to (this would be similar to existing Search system in main app or browser addin). Once the related item is picked, its name would be shown in that field (possibly in URL format) so you could click on it and be taken to that item.
eg. Item MyBank has field called Link which lists MyCreditCard. Click on MyCreditCard in the MyBank item, and I am taken to the item MyCreditCard.
I would probably put a similar link in MyCreditCard to take me to MyBank, or you could helpfully auto-add that :)
Hi @ddken,
Thanks for writing in.
We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback!
  • 4 years later...
Just a nudge on this. For the hundredth time I needed this again. Had a card that had some unique info on it, but needed to reference more info on another card. If only there was the option to add a 'link' field, where I could just click on that link and get taken to the other referenced card. If this was implemented, it would also be useful to have forward/backward history type buttons so could return to the original card. Forward/backward through history is a fairly common feature in many apps.
