June 12, 20206 yr I always synced using Dropbox, now I would like to sync using Onedrive. No problem on the laptop, but the app keep auto access the wrong email address for Onedrive, I've signed out of everything. Can't we just be asked wiche account it should use? Can not be hard to dev?
June 12, 20206 yr Hi @Bones, Welcome to the forums! Please open OneDrive in your default browser to check which account you are using to sync data. If you want to change the account, firstly logout from OneDrive in your default browser and reconnect sync. Thanks!
June 12, 20206 yr Author @Pratyush Sharma, I have logout from both the app and all browsers on the phone. It shows met on all the browsers that I am not logged on anymore.
June 16, 20206 yr @Bones Thanks for the info. If you've logged out from all the browsers, then it should be possible to sync with your preferred OneDrive account. Try connecting sync with OneDrive. If the issue persists, please share a screen-record of your phone.
