June 13, 20206 yr All my passwords have warnings on them. Ev3n0nesTh4tL00kL1keThis666***** Is there any way to remove these warnings so I am not admonished every time I use your app? Many thanks
June 15, 20206 yr Hey @Simon555 Welcome to the forum. Enpass lets you mark the items which you want to exclude from Password audit. Please refer to this link. If that doesn't help, please share some more info so that we can check further. On which device are you having this issue? Which Enpass version you using on the same device? Thanks.
June 22, 20206 yr Hi @Simon555, Thanks for sharing the details. Can you please try to change the password of any item using a password generator and let us know if that shows in the weak or very poor list.
June 26, 20206 yr Author Yes, it does generate 'excellent' passwords, such as "flatus-pad-numeral-crisply-mustang-jawed-daze-poncho" which is a bit too long for me to type, especially on a mobile phone, or "KC#os~0eH>1Ze8v3~Wk~B:Wc/7W(Wf79" which is impossible to type. EDIT: I've noticed that including any real words, even ones like th!5, cause a poor rating unless the string is very very long. I'm going through all my passwords now and changing the field from 'password' to 'text' so I can remove the warning labels. Edited June 26, 20206 yr by Simon555
June 26, 20206 yr Hi, Thanks for writing back in. I have noted down your input, and If you have any further queries, please feel free to contact us.
