June 21, 20206 yr I'm getting this today. How do I fix it? I've disconnected from the GoogleDrive account and reconnected fine. But the error persists. Edited June 21, 20206 yr by gpf Added screenshot
June 22, 20206 yr Hi @gpf, Sorry for the inconvenience caused to you. For quick troubleshooting, disconnect the sync from all the devices and reconnect it again. If your problem persists, please share the following details so that we can investigate where the problem could be. On which devices and OS versions (mention all) are you using Enpass? Which Enpass version are you using on each device? Does the Date and Time setting set to automatic on all devices? Does the last synced time get updated on the sync page? Thanks for your co-operation.
