June 22, 20206 yr When pressing the system-wide shortcut cmd+H in Enpass, the Application hidden (like intended). When you activate Enpass again (by application switcher), the main window stays hidden. Even actions that should give the main window focus (like the "About Enpass" menu item) nothing happens. The only way to bring the window back is selecting it from the Window menu or activating Enpass from the Dock (which sends a reopen Event by default). This is an unusual behaviour and I would expect Enpass not to hide the window on hiding the Application. Product: Enpass Beta Version: 6.4.2.667 System: macOS Mojave (10.14) Locale: de_DE
June 22, 20206 yr Hi @NilsW3, Sorry for the inconvenience caused to you. I have noted down this issue and notified the QA team to look into it. Thanks for your co-operation.
June 24, 20206 yr Hi @NilsW3, Update We are able to reproduce this issue at our end, and our team is working on it. Hopefully, the fix will be available in future updates. Till then, we will request you to please co-operate with us. Thanks!
