June 29, 20206 yr Having no luck setting up Enpass on a new laptop when trying to restore from my previous pc. I have tried the backup restore method and I receive "Internal Error -995" and when trying to restore. When I try from my cloud (dropbox) account I receive password and/or key used are incorrect and I am certain both are correct. I am open to suggestions and thank you for assisting. Kind Regards. John
June 30, 20206 yr Hey @ride2liv Welcome to the forum! We are sorry for the inconvenience caused to you. Please share some more info so that we can check further- On which device and OS version are you having this issue? Which Enpass version are you using on all of the devices? Are you able to access Enpass data on any other device? A screenshot of the issue, if possible would be great. Thanks.
July 1, 20206 yr Author Windows 10 Screenshot Attached, Enpass downloaded from windows store. Dropbox restore error screenshot attached Backup restore screenshot attached. I am 100% certain both the password and keyfile are correct as well. please advise and thank you for the help.
July 2, 20206 yr Hi @ride2liv Thanks for reporting this issue. I have noted down this issue and notified the QA team to look into it. If possible, please share the screenshot of Enpass version. Thanks for your cooperation.
July 2, 20206 yr Author Help/about is not available until I get into enpass, but it was the latest from the Microsoft store downloaded day before yesterday.
July 5, 20206 yr Have you tried to type the password in notepad? Your keyboard may be in the wrong keyboard layout. Did you used enpass 5 on previous pc and now trying to run it on enpass 6? Just checking.... Edited July 5, 20206 yr by TREMOR
July 6, 20206 yr Author I am certain it was entered correctly. using word to type, verify and copy paste. Good thought thank you. Its something with Enpass I think. Seems there are others with the same issue throughout the forum. have a great day tremor
July 7, 20206 yr Hi @ride2liv, We need a little input from you, so please let us know if you can access all your data on any other device. Thanks for your co-operation.
July 8, 20206 yr Author Thanks Pratyush, Enpass is currently on my desktop, old laptop and mobile device and all works well. Only when trying to setup on my new laptop does it complain as shown in my previous messages. I appreciate the assistance.
July 9, 20206 yr Hi @ride2liv, Thanks for writing back in. Our team is looking into this issue. If possible, try the website version of Enpass using this link (website version is given at the bottom of the page) and share your findings with us. Thanks for your co-operation.
August 28, 20206 yr Hey @ride2liv Sorry for the delay in response. The issue has been fixed in the updated version of Enpass. Please let me know if you still face the issue on the latest update. Thanks.
