July 5, 20206 yr I think this is a bug that shouldn't happen. I did an enpass reset but after I wanted to re-run the sync again I came to the conclusion that my webdav sync file was also gone. I did the enpass reset on win10 the webdav file was on a synology NAS. No worries I made multiple back-ups of the enpass vault. Edited July 5, 20206 yr by TREMOR
July 6, 20206 yr Hi, Thanks for using Enpass and writing to us. Please revert to us with the answer to the following queries and we will get it sorted out for you: On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Thanks for you co-operation.
July 6, 20206 yr I did the enpass reset on win10 home. Ehmm enpass version probably the latest (store automatically updates). Don't need to check Enpass, updates don't go that fast. And otherwise it's updated now. Edited July 6, 20206 yr by TREMOR
July 7, 20206 yr Hi @TREMOR, Thanks for writing back in. I have noted down your input and notified the concerned team to look into it.
