July 13, 20206 yr Hello, I noticed that Enpass constantly use up to 3% of cpu when it simply stays in background. I made some tests and I discovered that cpu usage drop to 0 when I manualy sync the vault but after a while it goes up again and If I unlock the main app I can see the vault icon spinning again, meaning, I guess, it was trying to sync. I've been using webdav since some months and I've never noticed the issue before, when I was syncing with icloud, so maybe it's related to enpass struggling to sync with webdav when locked in background. It's not a big issue but maybe there is a bug there you can fix. Regards. Edited July 13, 20206 yr by lucesan
July 14, 20206 yr Hey @lucesan Thanks for writing in. Every time you unlock your Enpass key-chain, an auto-sync is initiated (If Sync is turned on) and Auto-sync also happens after every 15 secs, while the app is in the foreground. Also, when you save any change in item details or master password, Enpass waits for 5 secs and initiates an auto-sync. To check CPU usage, please share the below info for testing purpose: On which device (along with OS version) are you having this issue? Which Enpass version are you using? The number of items and vaults in Enpass? Thanks for the co-operation.
July 15, 20206 yr Author Hi, thanks for the reply. MacMini (late 2012) Intel core i7 with MacOS 10.14.6 Enpass 6.4.2, 392 items and 2 vaults (but the secondary is nearly empty and I just synch the primary). Webdav on my NAS. The issue is very easy to reproduce: When Enpass is locked, right after a reboot, i.e, it takes up to 3.6% of cpu, constantly, until the first time I unlock it. When It gets synched, the cpu usage drops to 0%, for a while, until it eventually tries to synch again when locked. Unlocking, through the app or the internet plugin, fixes the problem again. Regards, Edited July 15, 20206 yr by lucesan
July 15, 20206 yr Hi @lucesan Thanks for reporting this issue. I have noted down this issue and notified the QA team to look into it. Thanks for your cooperation.
July 22, 20206 yr Thank you, have been seeing this same issue for a long time, would be great to have it fixed!
July 22, 20206 yr Hi @Andreas M., Sorry for the trouble you are going through. We are already working on this issue and hopefully, fix will be available in the future updates. Till then, we will request you to please co-operate with us. Thanks!
