July 16, 20206 yr my username does, but no the password field I've double-checked my login in enpass and the password value field type is set to "password"
July 17, 20206 yr Hey @electrolund Sorry for the trouble you are having. For quick troubleshooting, please disable the auto-fill feature and enable it again. Also, add dummy data in any of the login categories and then try to auto-fill and share your findings. For more details, please refer to this link of our user manual. If the problem still persists, please share the following details so that we can investigate where the problem could be. On which device and OS version are you having this issue? Which Enpass version are you using on the same? Can you please let me know on which website are you facing this problem? If possible, a screenshot or video of the issue to investigate it better? Thanks.
