July 22, 20206 yr Enpass app is called & is shown in notification bar when ever gmail app is opened or is active on screen. This behaviour started after latest android update.
July 22, 20206 yr Hi @pratheep, Sorry for the inconvenience caused to you. Please share the following details so that we can investigate where the problem could be. On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Thanks for your co-operation.
July 27, 20206 yr Hello, I'm getting this issue too. It's by no means a showstopper. It's just a bit of an irritating distraction. Pixel 4XL Android 10 Enpass version 6.5.0.380 Thanks.
July 28, 20206 yr Author On 7/22/2020 at 3:39 PM, Pratyush Sharma said: Hi @pratheep, Sorry for the inconvenience caused to you. Please share the following details so that we can investigate where the problem could be. On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Thanks for your co-operation. POCO F1/Android 10/miui 11.0.9 untouched Latest from playstore - 6.4.5.368
July 28, 20206 yr Author 3 hours ago, DodgyBlater said: Hello, I'm getting this issue too. It's by no means a showstopper. It's just a bit of an irritating distraction. Pixel 4XL Android 10 Enpass version 6.5.0.380 Thanks. Yes, same with me.. Just worried what data app is reading.
July 28, 20206 yr Hi @pratheep & @DodgyBlater Thanks for reporting this. I have noted down this issue and notified the QA team to look into it. Thanks for your cooperation.
July 31, 20206 yr Hey, Thanks for the patience. We would like to share that the issue has been reproduced by the QA team. Now our Dev team is looking into this issue to resolve and hopefully, a fix will be available in the future update. Thanks for your co-operation.
August 13, 20206 yr On 7/21/2020 at 9:03 PM, pratheep said: Enpass app is called & is shown in notification bar when ever gmail app is opened or is active on screen. This behaviour started after latest android update. +1 for me...also the Amazon app
August 18, 20206 yr Good to hear I have had same issue on Pixel 4XL running Android 10 QQ3A.200805.001 with Enpass 6.5.0.390. I have also had the same once only on the Pixel Launcher! But the GMail issue is every time I open GMail.
August 31, 20206 yr @juli999 Our team is aware about this issue, and we are already working towards a fix.
