August 27, 20206 yr Hi, Today I started using the Enpass extension for safari, on a Mac. How can I configure the keyboard shortcut that enters the credentials? Enpass documentation says this: But there is no option there
August 28, 20206 yr Hi @aristosv, Thanks for writing in. You can create the shortcuts by following the below steps: For Safari browser- Go to Enpass Setting -> Browser -> Keyboard Shortcut -> Setup Here(It will redirect to Safari Browser)Setup shortcut there. Also, you can refer to this screenshot attached. Note:- Shortcut works when there is login form webpage in background. Thanks!
