August 29, 20206 yr Enpass has a problem loading on Windows 10 Build 20201.rs_prerelease.200822-1922 (or the release prior to this) Not responding window for over a min or two. Data file on google drive. No other system problems Thanks..
August 31, 20206 yr @Wingfat Which Enpass version you're using? Also, share the system configuration like device model name, processor and the RAM.
September 1, 20206 yr Author Version 6.4.3 (666) Hope the info below provides the required information Windows 10 Pro Insider Preview.. Build 20201.rs_prerelease.200822-1922 Takes 60 seconds to open initially.. ( after reboot with no other programs running) Once closed opens instantly as expected. Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz RAM-16GB OS Name Microsoft Windows 10 Pro Insider Preview Version 10.0.20201 Build 20201 Other OS Description Not Available OS Manufacturer Microsoft Corporation System Name FIREFLY System Manufacturer To Be Filled By O.E.M. System Model To Be Filled By O.E.M. System Type x64-based PC System SKU To Be Filled By O.E.M. Processor Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4001 Mhz, 4 Core(s), 8 Logical Processor(s) BIOS Version/Date American Megatrends Inc. P2.50, 2/26/2018 SMBIOS Version 3.0 Embedded Controller Version 255.255 BIOS Mode UEFI BaseBoard Manufacturer ASRock BaseBoard Product Z270 Gaming-ITX/ac BaseBoard Version Platform Role Desktop Secure Boot State Off PCR7 Configuration Binding Not Possible Windows Directory C:\WINDOWS System Directory C:\WINDOWS\system32 Boot Device \Device\HarddiskVolume3 Locale United States Hardware Abstraction Layer Version = "10.0.20201.1000" User Name FIREFLY\Jeff Time Zone Eastern Daylight Time Installed Physical Memory (RAM) 16.0 GB Total Physical Memory 15.9 GB Available Physical Memory 11.0 GB Total Virtual Memory 18.3 GB Available Virtual Memory 11.5 GB Page File Space 2.38 GB Page File C:\pagefile.sys Kernel DMA Protection Off Virtualization-based security Not enabled Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not Modern Standby, Un-allowed DMA capable bus/device(s) detected, TPM is not usable Hyper-V - VM Monitor Mode Extensions Yes Hyper-V - Second Level Address Translation Extensions Yes Hyper-V - Virtualization Enabled in Firmware Yes Hyper-V - Data Execution Protection Yes
September 1, 20206 yr @Wingfat Thanks for sharing the details. We'll look into the problem and share updates with you.
September 1, 20206 yr Author Thanks for looking into this.. As a disenfranchised 1Password user, I rely on Enpass for my Android, Windows, MacOs, and Linux systems. It meets or exceeds all my needs syncing with Google drive for security. The model the 1Password switched to... central depository of all users data, encrypted or not , is far too alluring for hackers. I prefer your decentralized approch to user data.
