August 29, 20206 yr My version go Enpass did change august 27 2020. Where is my data base of the old version?
August 31, 20206 yr @Andre Lapierre Hello and welcome to the forums. Which version of Enpass are you using now, and which version did you use earlier? Also, on which OS did you update Enpass? Were you using any cloud to sync Enpass data?
