September 30, 20179 yr Hello, Just started to use the Edge extension and its working well, but I think the UI needs to be tweaked. I have the Dark Theme enabled for Microsoft Edge browser and I noticed the Icon is very hard to see, it looks very dimmed out. Now at first I think that this is suppose to be by design and when you get to a page it recognizes it would turn bright white and stand out, but during testing I signed out of my google account and even though it found the google login the icon did not change. 1.) I don't know if its possible for the icon to change color, but it would be nice to keep it dim on pages its not being used, and light up when it can submit a password for you. I do know that the "Pocket" extension changes to Red when you click add to pocket. 2.) If #1 isn't possible I hope the extension can support the Microsoft Edge dark theme so the icons is visible. I did check the options of the extension and there is no where to enable dark theme.
October 1, 20179 yr The Enpass Extension is almost invisible Edge with Dark Mode enabled. Please create a new icon with colors that are viewable in both Dark and Light modes. Thanks
October 3, 20179 yr Hi guys, Thanks for writing in. Our dev team is already working on it and fixed will be available in an upcoming release. Cheers!
